Dyno Results After 228/228 and 5.3l Heads
The dyno graph after tuning my 2001 Coupe with the following mods is provided below. Results were 414 hp and 384 ft.-lbs.
TSP Stage 2.5 5.3L heads;
TSP 228R cam (228/228 .588/.588 on 112 LSA);
TPIS longtube headers, X-pipe & Random Tech high flow cats;
K&N FIPK;
Powerbond 25% underdrive pulley
Comments are welcomed.
Rick
K&N FIPK;
Rick
I think that looks great. you should FEEL great SOTP acceleration. Not stressful on the springs.
again your not going to win dyno bar racing, but that isn't what you wanted anyway.
Drive ON . . .
:stomp:
Drive ON . . .
:stomp:
That looks pretty good. Are those corrected numbers? Did you dyno it before the mods? I'm looking at a similar spec. cam.
Rick,,,
I've got same cam,,, but TSP 243 heads,,, but it's not running yet. I'm wondering,,, did you compute DCR and if so where did it end up? BTW,,,, numbers look good!
Lastley and maybe most importantly,.,,, where's the sound clip?
Visited with my tuner today. The AFR is set at 12.5. He set it low for safety due to how hot it gets in Oklahoma in the summer when I run road courses.
He said we'd easily get 20 hp bumping it up to 12.8 - 13.0. Possibly up to 30 hp.....
I thought there was more to be had.
Rick
Rick
Cruise-In III Veteran
Even with your AFR's those numbers seem light to me.
99LS1 with slightly worked old LS1 casting heads, and a 218/222 113 sub 580 lift Cam and 12.5 AFR's netted me 409/390 on that engine tuned and dyno'd by ECS. With FLP Headers and Vararam.
That said, if you're happy that's all that counts.
