F/S 1995 C4 Coupe, 365HP LT1 Coupe, 6-spd, Road Race/Autocross prepared
For sale: 1995 Chevrolet Corvette 6-spd Coupe. With its hot engine and many heavy-duty parts, this car is ideal for the weekend track or autocross junkie.
42,316 miles. VIN available upon request
Asking price: $14,500 OBO
Car is located in Morris Plains, NJ. ZIP: 07950
Options
Admiral Blue Metallic
6-Spd
3.45:1 performance axle ratio
Z07 Adjustable Performance Suspension
Delco-Bose Gold AM/FM/Cassette/CD
365HP LT1 Engine
Elliot Portworks LE-1 ported heads - 195 CC Intake Ports. Port pics available.
Crane 10308-1 dual valve spring, retainer and lock kit
7/16" rocker studs
Competition Cams Pro Magnum 1.6 roller rockers
Hardened pushrods and guideplates
GMPP LT4 Hot Cam
GMPP LT4 Extreme Duty timing set
Melling high volume oil pump
Accel 30lb/hr fuel injectors
Fresh main and rod bearings
Custom PCM calibration
Extras/Upgrades
Corvette 5-spoke wheels (Silver - 96 Corvette Collector Edition) with nearly new street tires (4)
Corvette 5-spoke wheels (Black – 96 Corvette Grand Sport) with Kuhmo track/autocross tires (4)
Kirkey Intermediate Road Race seats (driver&pass) with black cloth covers
R-D Racing S/T Frame Rollbar with camera mount – reinforced and welded to chassis
5-point competition belts (driver&pass)
R-D Racing Camber Brace
DRM Wilwood 6-piston front brakes with 13x1-3/8" rotors
Front brake ducts and center-ducted backing plates
Oversized master cylinder and adjustable proportioning valve
Stainless steel brake hoses front and rear
DeWitts aluminum radiator
Oil cooler with thermostat
Oversized remote oil filter
Ceramic coated short-style headers
Random Tech stainless steel cat bypass pipes
Urethane suspension bushings
Turn-One Performance power steering pump
K&N air filter and opened lid
Battery relocated to rear compartment for better weight balance
4-wheel track/autocross performance alignment
Emissions bypasses
Cats bypassed
EGR valve removed
AIR removed
PCM reprogrammed to disable emissions diagnostics (so no fault codes or "check engine" light)
This Corvette is set up well for track and autocross use. It is currently not street legal due to the emissions bypasses, but all removed emissions equipment is included with purchase upon request, can be re-installed by buyer for street use. Contact seller for installation quote. Cam and head port work are not emissions-certified, but vehicle should be able to pass smog tests in most states with factory emissions components re-installed. However, no emissions guarantees are made.
Vehicle sustained minor damage to right rear quarter panel and bumper cover in rear-end collision in 2007, but this damage has been professionally repaired.
Missing hinged cover for interior console ashtray/cupholder.
Rollbar is reinforced and professionally welded to frame and roof. Photos of installation available.
All oil system plumbing is done with stainless steel AN10 braided lines. System has connections for 3qt AccuSump oil accumulator (AccuSump not included).
There is some minor flatspotting or cording on autocross tires - may require rebalance for high-speed use. Two will need replacement soon. Street tires are fairly new, and have most of their tread left.
Vehicle is equipped with power seats, butthe driver's seat currently has a fixed mount to the frame and rollbar for safety purposes. Original power slide will be included with purchase if requested, and can be re-installed by seller. Passenger seat power slides function normally.
The seats are much stronger and more supportive than the factory seats in track or autocross use, but they are fully padded and quite confortable for the street as well. However, they do make it a bit harder to get in and out compared to the OEM seats.
OEM seatbelts are still installed in vehicle and are fully functional.
Has never been smoked in. Occasional tire smoke around outside, however.
Vehicle has always been garaged or covered. Custom-fit cloth cover included with purchase.
Delivery available within 200 mile radius - inquire for pricing.
Options
6-Spd
365HP LT1 Engine
7/16" rocker studs
GMPP LT4 Hot Cam
Extras/Upgrades
Emissions bypasses
Cats bypassed
EGR valve removed
AIR removed
Rev limit has been increased to 6050. Valve train should be good for 6300 all day according to Elliot, but others on this forum have said that with the stock LT1 bottom you don't want to exceed 6100 for too long. Street, drag race or auto-x use would probably be fine with a higher rev limit, but for road race 6050 seemed safer. The motor definitely wants to keep pulling past the rev limit...
I kept the engine compartment looking as close to stock as possible to avoid failing inspection - here are some pics. (Sorry for the sun glare)
