race helmets
The most current rating is SA2005. Most groups allow the current
rating and the most recent previous rating, which right now is SA2000.
So buying a current helmet, SA2005, should keep you good for close to
ten years. Beware any deals on SA2000 helmets.
Randy
Randy
Find a shop where you can try them on before you buy.
Cruise-In VI Veteran
No...SA is Special Application meaning race. That is the Fire resistant helmet. M is motorcycle. Nasa still allows M rated helmets but most groups are getting away from them. Go with SA. You can always use SA on a motorcycle if needed.
Bob
Bob
SA-rated helmets don't always have a DOT rating sticker. Here in WA an SA helmet without a DOT sticker is not legal for highway motorcycle use.
M-rated helmets typically have the oval DOT sticker on them and on the outside. My Bell Mag-4 has a sticker under the liner that states it has not been approved by the federal DOT and as such is not legal for street/highway use.
I picke dup the SA 2005, and if I remember the rules for SCCA Solo II you can go as old as SA95, so a SA2000 if cheap enough might be worth it for a few years. But I'd suggest checking on what events you plan to race for regulations.
SA helmets go through a multiple acute impact test ( bouncing your head off of the roll cage in a rollover).
M helemts do not go through that test
This is just what our local club does. I can't speak specifically about national or other local clubs.
