Integrated tranny cooler
How would getting a radiator with an integrated engine oil cooler and auto tranny cooler (97-00 so you get the treaded fitting) work in a 2003 ZO6? Take the integrated tranny cooler add a Telton pump, run lines back to the tranny. You would need a check valve on the lower line so the fluid doesn’t drain back to the tranny?
That would make a nice clean solution for a daily driver/track car.
What do you guys think?
Thanks.
Thanks.
Former Vendor
The only reason you shouldn't do it is because of the design of the Auto tranny cooler. Auto trannies push a ton of pressure in and out of the cooler. I don't think you could or should find a Manual tranny pump to not make the cooler a huge road block.
Randy
Randy
