how to get heads up display on video? Anyone have success?
Old 06-17-2008, 07:29 AM
speedneed
speedneed's Avatar
Default how to get heads up display on video? Anyone have success?
I have a Sony mini DV mounted to the harness bar. Would like to figure out a way to get some on track video with the heads up display included. Any body been able to get this setup? Every time I show someone a track tape the want to see the speed with it. I'm not ready to spend $2000 for a Traqmate just to get the speed added to the tape. I know some one has an answer!
Old 06-17-2008, 08:19 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
the viewing angle is so narrow, you would almost need to mount the camera in your face. Unless you mount the camera directly over your shoulder, I think it will be impossible (maybe even then)
Old 06-17-2008, 09:30 AM
Dave OH32
Dave OH32's Avatar
..+1
Old 06-17-2008, 09:35 AM
plaster
plaster's Avatar
Connect a bullet cam to the camcorder and slide the bullet cam over your ear (like a pencil) inside your helmet and you should get at least some of the hud.
If not marked, mark the top so you can verify it is aligned in the rearview mirror.
Old 06-17-2008, 11:41 AM
speedneed
speedneed's Avatar
That's gotta be one small bullet cam to fit between my head and helmet!
Old 06-17-2008, 11:54 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Is there a was to tap into the data that goes into the HUD and record that?
Old 06-17-2008, 12:21 PM
southernshark
southernshark's Avatar
why can't you put a bullet came on top of the dash right on top of the gauges?
Old 06-17-2008, 01:23 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
You mean like this?
http://www.youtube.com/watch?v=1vEzK1vESDU
Youtube's compression hurts the image of the HUD significantly; it looks a lot better at full resolution.
I'm also going to go to a narrower field of view lens to get the HUD to be a bit larger in the FOV.
Camera is a Sony 520 bullet camera I got off of Ebay.
HTH, and have a good one,
Mike
To how to get heads up display on video? Anyone have success?
Quick Reply: how to get heads up display on video? Anyone have success?
