I'm looking for a reasonably price Diff cooler for the C6
Old 06-20-2008, 12:55 AM
jbsblownc5
Support Corvetteforum!
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
Default I'm looking for a reasonably price Diff cooler for the C6
While my 08 C6 Z51 is certainly not a dedicated track car, I do like to get out on some spirited canyon runs, as well as some romps on the roadcourse. I'm heating up the clutch pacs too much and need some cooling protection. I've already switched out the Z51 oil cooler for the Z06 cooler, but need some protection for my diff.
I'm looking for the best bang for the buck in this area.
Thanks in advance!!!
JB
Old 06-20-2008, 02:20 AM
AMERICANMUSL
AMERICANMUSL's Avatar
Hey Joel!
Price no object(PWR) in Wildomar, Ca by Cunningham Motorsports...they are precision IMO. They may give you a good price!
Bang for your buck...Summit Racing for what you're looking for.
You may want to check HRP and Racepartwholesale, Porterfield as well.
Good luck brother---Ed
Old 06-20-2008, 09:05 AM
LS3FORME
LS3FORME's Avatar
Jb where did you get z06 oil cooler, and would you do that again or go aftermarket, I live so florida and just tracked my z51 and oil cooler does not cut it. Diff. might be inorder to so I will follow the tread.
Old 06-20-2008, 10:05 AM
davidfarmer
davidfarmer's Avatar
just go to HRP and order an electric fluid pump and a heat exchanger. The C5 had a 20mm fittings, and I assume the C6 is the same, so you'll need some adapters and AN line to plumb it all up.
http://www.hrpworld.com/index.cfm?fo...action=product pump-significantly cheaper than weldon etc
http://www.hrpworld.com/index.cfm?fo...ction=category exchangers
Summit/Jegs also has them
Old 06-20-2008, 10:10 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Do you have coilovers??? If not you will have one hell of a time getting a drain fitting to work. I have a kit for 649 that comes with pump, cooler, lines. It works very well!!!
Randy
Old 06-20-2008, 10:14 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Originally Posted by AMERICANMUSL
Hey Joel!
Thanks Ed!!! I'll look into that stuff.
Old 06-20-2008, 10:17 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
I found a next to new Z06 cooler on the boards for $250 delivered. I just pulled the clips on my Z51 and it fit like a glove on my 08 C6. I've done one canyon run, and it seemed to do pretty well. I've yet to track test it, so I can't say if this is the exact fix or not for the C6, but it works for the Z06.
Old 06-20-2008, 10:25 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Thank you for the links David!!!
Old 06-20-2008, 10:36 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Randy
Hey Randy,
This C6 was supposed to be my backup car... no coilovers on it. I do like to track it once in a while. Problem is, one weekend of me driving it hard at Spring Mountain has beaten the hell out of the clutch pacs.
Why will it be hard to fit the drain line, due to the leaf spring???
Thanks, I'll probably give you a call if I can get a minute today.
Old 06-20-2008, 10:44 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Originally Posted by jbsblownc5
Hey Randy,
The leaf is right under the drain hole. You can drill and tapped a out port. But I suggest pulling the diff, because a bunch of shavings will be harder on the diff then the heat.
Randy
Old 06-20-2008, 10:47 AM
davidfarmer
I never had any problem with clearance on a C5 with leafs. It's snug, but not a problem. I haven't done a C6.
So does the C6 not have a threaded drain hole on the bottom????
Old 06-20-2008, 10:54 AM
spazegun2213
spazegun2213's Avatar
oh, and if you need coolers, fittings, etc try www.racecityraceparts.com
Old 06-20-2008, 11:35 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
The C5s are no problem. But when they moved the stuff around for the C6 it was a huge road block.
Randy
Old 06-20-2008, 09:28 PM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Randy
I had the guys at Unitrax look under my car when they put the diff back in today, and they said there was more room under the drain on my 08 C6 then there was on the C5s...
Old 06-21-2008, 03:18 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Humm, that is great news. Here is a picture of the worst case situation. We ended up building a guard also, incase of a off.
Old 06-23-2008, 01:26 AM
jbsblownc5
jbsblownc5's Avatar
St. Jude Donor '08
Randy,
Do you think your kit will work on an 08???
To I'm looking for a reasonably price Diff cooler for the C6
Quick Reply: I'm looking for a reasonably price Diff cooler for the C6
