Racers with AFR heads on LTX blocks.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Check this out, I'm sure glad I did.
Just a few pics of some of the preliminary block work.
Because some folks might not know... When you use AFR cyl heads on an GEN II LTX, the front drivers side cyl heads oil return gets blocked off completely because of a shelf (its actually a casting support for the waterpump bolt) that is cast in to the GEN II blocks (not there in a regular SBC). So we don't have any problems I modify that shelf so, oil will drain out of the front of the head properly. Most people who are having or had problems with AFR's on LTX motors don't even know this is a big part of their problem....
Will
Will
Sorry, I didn't take any pics of the block deck surface and the shelf there before I modified it (cut the trench in it for the oil return). I guess it kinda makes it hard to see precisely what I did.
However if you take an AFR head and lay it on a bare LTx block then look down the drivers side front oil return, it will immeadiatly be aparant that its blocked off completely. I just took a sharpie (marker) and marked the deck surface where the oil return (with the head on of course), then took the head off and started cutting. Just lay the carbide bur (3/8 diam) up against the edge of that shelf at a 30*-45* angle towards the lifter valley and gradually grind a "trench" over to the mark. Once you reach your mark, lay the head back up there to check and make sure you have it big enough and far enough over. Keep grinding and checking until you do.
These pics with the die grinder in place should help.
No worries about how deep you grind there, that shelf is solid... BUT be very careful as one slip could f'up the deck surface right near the water inlet (which as you can see is right below the bur).
What else would you like to know?
Will
Will
