Pilot sport cups pressures?
Old 06-21-2008, 06:54 AM
ErnieN85
ErnieN85's Avatar
Default Pilot sport cups pressures?
I'm headed to VIR next weekend and need an idea of where to start out. cold & hot
Michelin says 32 front & 36 rear hot. My thoughts are is this on a corvette?
anyone using these and what have you found?
Old 06-21-2008, 08:22 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
personally I would run them HOT 33F / 30R and then adjust from there. When I had them I found I didnt like them at the higher pressures.
Old 06-21-2008, 09:25 AM
AZ FASTEST
Support Corvetteforum!
AZ FASTEST's Avatar
I used to start them at 28 front and 26 rear and they would heat to 34 /32 which worked well for the tire in Arizona on our tracks.
Old 06-24-2008, 01:54 AM
Cloaked323
Cloaked323's Avatar
I run them cold at 27 all around but what do I know I'm just having fun.
To Pilot sport cups pressures?
Quick Reply: Pilot sport cups pressures?
