LGM C6 ZO6 Brake Cooling Ducts
Old 06-22-2008, 07:18 AM
C6RAPTOR
Support Corvetteforum!
C6RAPTOR's Avatar
Default LGM C6 ZO6 Brake Cooling Ducts
I had front brake cooling LGM spindle plates with DRM ducts and 3.5” hoses on my 05. I had tire clearance problems with this setup. I found out that LG Motorsports has an OEM C6 ZO6 cooling duct that they modify to take a 3” brake cooling hose.
I ordered the LGM ducts and installed them last week. This is one sweet item. For one thing you can really clamp down on the hose clamp because LGM uses an aluminum welded and riveted duct end that the hose slips over.
The C6 ZO6 duct stays closer to the frame then the DRM unit and the hose position is now more to the center of the wheel to give better tire clearance.
Nice job, Lou, Anthony and Bobby.
Quick Reply: LGM C6 ZO6 Brake Cooling Ducts
