Synpower Brake fluid MIA-I'm angry
So I've been using Synpower in all but my most hardcore cars for several years now. I've completely TOASTED the best pads, but never boiled synpower. I cooked a set of DTC70's this weekend at CMP, but after cooling down, brakes came right back (proof that the fluid didn't boil).
Anyway, appearantly the silver Synpower bottles are being replaced with Bluid bottles, and the boiling point is lower. They still call it synthetic, but other drivers that have used it say it really isn't as good.
Anyway, if you are like me and appreciate being able to pick up a 32oz bottle of great fluid for $6, let Valvoline know!
just got an email from Valvoline..
The SynPower line of chemicals has been replaced with the new Valvoline Performance Chemicals. The new synthetic brake fluid is the same as the SynPower the labels have been misprinted. Sorry, for the confusion we are correctly working to resolve this issue. Thanks for choosing Valvoline!
are they to be trusted????? Different labels, different skews......?
Funny you mentioned that David, I noticed it about a month ago too. I've always used Synpower w/o issue. I like to flush my brakes fluid a lot so the price was right, and having it readily available at any parts store in a pinch was awesome. I'll be interested to see how this 'new stuff' works out.
-TJ
-TJ
My 20 years has proven (to me) that 90% of brake fade is PAD related, not fluid. Synpower has proven to be a great product, and I hope this new product is the same.
I agree, ATE is not great fluid. And with rising costs, I AM willing to spend $6 on fluid instead of $40 to offset costs that I can't control, especially for a product that has proven worthy.
Dave,
One of the guys on the GTO board had an inside contact at Valvoline and confirmed that the new fluid is chemically identical to the old SynPower. If you check out the Data Sheet for the new fluid, it has the same specs as the SynPower branded fluid. I have no idea why they changed the boiling points on the bottle but kept them the same on the data sheet.
-Matt
-Matt
Former Vendor
I've often wondered the alternative to synthetic fluid? Organic?
I note the mention of the Wilwood exp and while great I'd urge caution with all but more hard core track days. Use 570 to begin with. The exp stuff won't offer you the shelf life needed unless you refresh it weekly. In a matter of a few months the fluid won't be as stable and likely below the level of others for dry boiling.
I agree fully: pads will nearly always fade before fluid. But... stock pads are not all that thick either...
I have personally boiled valv syn power with pf01's. in fact syn power was the only fluid i have ever boiled.
if u want street grade fluid that is trackable, try the castrol lma.
and I got a bridge...............
I noticed the boiling point change this year too. I used it once and all was fine, but thats on a baby track like Pocono North. I would never use it on a large track like Watkins Glen.
So Ill be looking for their corrected specs on the bottle.
-TJ
-TJ
Well at least now I know I wasn't imagining things when I saw the new bottles had a lower boil point on them. I went to buy some a few days ago and noticed the new bottle and read the label. I didn't buy it at the time because I thought maybe they were going to have two levels of synthetic available for some reason. I'm running low now and will probably have to try it out.
I just used the new stuff this weekend on my Neon with Carbotech pads. The pad backing plates were white when I took the pads off, but the fluid never seemed to boil. The only times I have boiled the Valvoline fluid were at Gingerman in my 69, which is pretty heavy. Gingerman is hard on brakes.
My experience is that once the fluid boils, it must be bled out. There are too many bubbles in the fluid to not bleed the brakes. I will continue using their fluid.
Ken
Ken
A friend runs a quickie-oil-change shop, and he is going to load me up with the Synpower bottles just to be safe. I'll try the Blue stuff when I have to, but at the same price, I'd rather know I'm getting the old Synpower.
Prestone makes a full synthetic 500deg fluid, but it comes in 8oz (or 12). By the time you get enough to use, the savings isn't enough to not just get AP/etc.
