Dip Stick Popping Out At Poconos
Old 06-27-2008, 09:26 PM
DRM450
DRM450's Avatar
Default Dip Stick Popping Out At Poconos
I have a 02 Z with a maggie supercharger. My dip stick kept popping up after a few times around the south track at the Pocono's. I was told I should have a oil seperator. Has anyone ever heard of this?
Old 06-27-2008, 10:32 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
Might want to ask this question on the Forced Induction Forum - I'm thinking it might be excessive crankcase pressure caused by the S/C. did this occur before you added the S/C? Noticed you're from Saugerties - I'm originally from Hunter (up on the mountain) - have relatives in Saugerties.
Old 06-27-2008, 11:33 PM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
I've seen that happen on 3 cars now, and they all had very bad things happen soon after. Let's hope not, but I'd keep some padding in the budget.
Old 06-28-2008, 07:38 AM
varkwso
varkwso's Avatar
excessive crank case pressure - it is a bad sign - just ask ZO6cool....
If you are very, very lucky your PVC (positive crankcase ventilation) was blocked or obstructed....
Most other fixes are a band aid to a leaky cylinder or two...
Old 06-28-2008, 09:20 AM
Snuckley
Snuckley's Avatar
wire tie the stick so it stays put with safety wire....
Old 06-28-2008, 10:19 AM
stairman
stairman's Avatar
Not a good idea, it is popping out because something wants out, if it does not get out there it will find another place. You need to find the cause and give it an appropriate tank to vent to.
Old 06-28-2008, 12:46 PM
DRM450
DRM450's Avatar
Thanks for the help
Old 06-28-2008, 02:13 PM
Z06cool
Z06cool's Avatar
Very bad sign...
Old 06-29-2008, 12:54 AM
ibjamin
ibjamin's Avatar
You have too much crankcase pressure, very likely from piston blow bye. If stock pistons, you likely have cracked the ringlands from detonation. Do a leakdown test on the cylinders to verify and be prepared for a rebuild.
Catch cans, breathers, etc. are band aids that don't fix the root cause.
George
To Dip Stick Popping Out At Poconos
Quick Reply: Dip Stick Popping Out At Poconos
