tire wear on insides
both side on my inner front tires (INNER MOST 1 INCH or so) were wearing really fast compared to other areas of my tire it almost looked real weird. almost like the inner was a valley and the rest of tire was a plateau
anyone else has that happen on their Z?
looks like time to get an aliignment
here are some pics
same wear on each driver and passenger side
here are some pics
How much camber are you running on the front ?? Mine are in the same shape except the whole inner tread block is worn down. I run 1.5 deg negative in front as a street track compromise. Your situation could also be a bad toe setting ----- count on getting front tires shortly - you will be in the cords within a few miles.
The settings will really depend on what type of driving ( how much street - how much track) you do. Check out the Tire Rack and Phoenix performance web sites for recommended settings. Also do a search here and in the tire section - lots of good info.
HERE IS THE PDF SHOWING THE OLD AND NEW SPECS
I asked for the 1.0 front camber sinec that is what allanlaw recc. for street driving along with track
http://sio.midco.net/dvandentop/alignment.pdf
