How to remove pass selt belt and pass through B-pillar panel?
Tried to remove my B-pillar panels to install a harness bar. Disconnected the seat belt anchor on right side of passenger seat on my 08 coupe. THere is no physical way the size of the anchor will fit thru the slot in the B pillar panel. It is a huge L shaped bracket with a switch assembly attached.
THis darned harness bar installation has turned into a nightmare.
Has anyone figured out how to take the seat belts apart to fit thru the B-pillar slot?
thanks but that doesn't explain the passenger seat. THe belt anchor is a huge L shaped bracket with an electrical switch attached (about 18MM thick by 25 mm long)
