SCCA rollcage: Instead of a diagonal on the rear hoop do you think this will suffice?
See how the two bars go down from the rear cross bar
And there will also be the bar that comes from about a 1/3 of the way to the passenger side on the main hoop to the frame on the opposite side
You can see it here, just above and a little to the left of the seat
I'm not a licensed Scrutineer so my opinion doesn't count for much, but I would say no. The GCR is quite specific relative to bracing of the main hoop and your layout doesn't meet the requirements of 9.4.B.2 in terms of lateral bracing. Neither of the two braces you have would withstand lateral crash impact IMO, both because of insufficient triangulation and because they're not tied into the rigidity of the main hoop itself as the required diagonal brace is intended to be - I can't tell from the pics exactly what they're tied into. Regardless of that, I would question the structural integrity of the design.
They get real picky on details, little details. If something is just not the way it was written in the GCR, your toast.
Do believe the Door bars must be the NASCAR style door bars ( TWO ) and bracing in those door bars as well.
Rear bracing:
These pics may be a bit old and not sure if they are up to tech specs, but they give you an idea
source: http://www.rollcageguy.com/
Rear bracing:
Here is a pretty good link with the most current info I could find.
http://www.scca.org/documents/Club%2...chBulletin.pdf
I agree with the above. In addition, the surge tank for the coolant in the above car is far too low to do anything. It may actually make cooling worse being that low by further lowering the coolant level and increasing the air pocket in the cooling system. Surge tanks must be mounted so the water line in them is the highest point in the cooling system.
-V
-V
Yeah I'm definately adding it now
And I don't know who owns the car above with the surge tank but I do know it was local to me at one time in the 70's
I'll get pictures of my cage once it's completed
I have another question do you guys weld the cages in at ride height or with the frames on jack stands?
