What else do I need? (oil cooler help)
Old 07-08-2008, 09:44 AM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Default What else do I need? (oil cooler help)
I just bought a used Oil Cooler and a used LPE Oil Cooler Adapter Block and need some parts to make this all work.
The oil cooler is -12 and the block is -10. I need all the necessary parts in-between the adapter and the cooler, so all lines, hose ends, necessary tools to connect lines to hose ends, heat shield protectant, etc.
Can anyone provide me a list of what I need? Length of hose, etc...
Many thanks in advance!!
Adam Boca
Old 07-08-2008, 03:54 PM
spazegun2213
spazegun2213's Avatar
Adam,
Who made the cooler core? if its a setrab, you can remove the -12 ends and buy -10 ends, which is your best bet. Other than that here is my parts list for my oil cooler that I'm installing this weekend
10' -10 SS hose
4 90* swivel fittings
6' 1" ID thermo-tec heat wrap
however, if i were you I'd do this.
10' -10 SS hose
2 90* -10 fittings
2 an10 to an12 fittings
2 90* -12 fittings.
installing the ends is a little work but not a problem. I used some old oil to help things fit together, but took me about an hour to get all 4 ends on. After that you might need to solder some wire on to extend the oil temp probe so it will fit on the LPE block.
summit has everything you need as far as the plumbing. and dont worry about the special AN wrenches, just be ginger with them.
good luck
-Ross
Adam Boca
Old 07-08-2008, 04:19 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Adam,
I have a good sheet on how-to build the AN lines. I just need a fax number.
Randy
Old 07-08-2008, 04:28 PM
Adam Boca
Adam Boca's Avatar
Awesome Ross and Randy!
Found everything needed on Summit....boy this is not going to be cheap! LOL....
Randy, 270.781.5286, attn: Adam
Many thanks!
Adam
Old 07-08-2008, 05:18 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I hope you got the fax Adam. If you have seen "office space" the movie, then you will understand my fax machine.
Randy
Old 07-09-2008, 09:56 AM
Adam Boca
Adam Boca's Avatar
LOL! I was wondering! Many thanks again Randy..
Adam
Old 07-09-2008, 10:10 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Are you going to come out ahead vs. just buying a kit from a vendor?
Old 07-09-2008, 10:30 AM
Adam Boca
Adam Boca's Avatar
I think in the long run yes...
I got the Oil Cooler and the Adapter block for $60 shipped...The lines and fitting will run around $330 shipped...So $390ttl. The Lingenfelter kit is $600, Pfadt (which is what I really want) is $845....So all in all I will save $210..
Adam
Old 07-09-2008, 11:04 AM
Gary04Z06
Gary04Z06's Avatar
I have two SS Aeroeqip lines -10 fittings that I made up for my oil cooler, took off when I sold the car. PM if you are interested.
Old 07-09-2008, 11:21 AM
Adam Boca
Adam Boca's Avatar
PM sent Gary...
Thanks!
Adam
Old 07-09-2008, 11:22 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Adam,
I can do better then the 330 for a couple lines and fittings. I don't know the cost for the -12 to -10 adapters but I don't think they are too much money. I will try to figure out a price if you haven't pulled the tigger yet. I sell a block adapter, lines and fittings for 329.
Randy
Old 07-09-2008, 11:30 AM
Adam Boca
Adam Boca's Avatar
Randy,
I have not pulled the trigger on anything yet (except for the cooler and block adapter), and it may be several weeks (saving pennies), so take your time and let me know..
Thanks!
Adam
Old 07-09-2008, 11:57 AM
Gary04Z06
Gary04Z06's Avatar
PM sent Gary...
Thanks!
Adam
Replied, thanks.
Old 07-16-2008, 03:40 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
hey Adam did you get hooked up???
If not give me a call or a pm
Randy
To What else do I need? (oil cooler help)
Quick Reply: What else do I need? (oil cooler help)
