Longer studs
Longer studs
Going to get some race wheels, and I want to get some longer studs at the same time in order to be able to run spacers. Does anyone know the ARP stud that's longer than stock and will fit a C5 hub?
1 Post
Cruise-In II Veteran
1 Post
They are really long, I cut mine down on a lathe that much and I still had more than stock. They are at least 3/4 (15mm) longer than OE.
ARP stud catalog showing GM units. GM Racing also has a set of longer studs.
I'll never buy wheels again that require longer studs or spacers....too much work every time you need to change bearings, or have a stud fail.
http://www.davidfarmerstuff.com/apr-wheel-stud.pdf
Yep, that's the catalog page I was looking at. The stock studs are 2", using the L1 measurement from above. I've got some photos of Kodiak wheels with stock studs, and it looks to me like the longer studs are called for. It may look dorky on the street but I don't care about that too much.
Whew...based on the title I was worried you were looking for something else.
I use the ARP studs and think they are crap...structurally sound (so far) but the coating on them makes the first several uses difficult and they seem to cross thread much easier than others I used. I had another brand before (I think I had Moroso) and liked them better.
Vetteless
St. Jude Donor '09
The Kodiak wheels I run definitely require longer studs - I'd say 1" longer than stock. I have a full set of ARP's that I'm planning to install this winter when I do all the wheel bearings - mine are 3".
