Holy Cow 1.50 and 1.53 Later G's
Old 07-14-2008, 12:24 PM
97C5inSD
Support Corvetteforum!
97C5inSD's Avatar
Default Holy Cow 1.50 and 1.53 Later G's
I couldn't belive it looking through my Traqmate data from the last autocross on my fastest run I managed to Pull 1.5 Left G's and 1.53 Right lateral G's
My car has pulled alot of Mid 1.35 to 1.42's before on diffrent courses and i seen alotta 1.45's outta our course this last time. Managed a top speed of 68.5 mph. Hmm well it was a good work out for me before the SCCA national Tour event i am going to.
Anyways just had to share my shock and amazement
Old 07-14-2008, 12:29 PM
dvandentop
dvandentop's Avatar
damn that is nuts, what section where you seeing the highest g's yesterday??
Old 07-14-2008, 12:41 PM
97C5inSD
97C5inSD's Avatar
The First one was basically turn four or the frist left turn we had going into that open box area. you could kinda draw your own line through it
The next High G turn was the last As we go into the straight to the finish line.
Damn if i knew how to copy this info and post it on the web i would. Guess i need to do more work on this thing
Old 07-14-2008, 12:45 PM
throwit
throwit's Avatar
I guess the next obvious question is what tires are you running and what sizes are they?
Old 07-14-2008, 01:03 PM
97C5inSD
97C5inSD's Avatar
Oh sorry guess i shoulda put in. the car setup.
DRM Coilovers
Hotchkins sway bars
VP Poly bushings.
Khumo V710's 315/35/17X10.5 front 335/35/17X11.5 Rears CCW Classics
Alignment
Front
-2.0 camber
6.6 caster
-.03 toe in
Rear
-1.3 camber
-.44 toe in
Old 07-14-2008, 01:06 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
That pretty damn good!!!
Randy
Old 07-14-2008, 01:24 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice
Old 07-14-2008, 01:36 PM
throwit
throwit's Avatar
Khumo V710's 315/35/17 front 335/35/17's Rear
What size wheels are those on??
Old 07-14-2008, 01:41 PM
97C5inSD
97C5inSD's Avatar
10.5 front and 11.5 Rears CCW classic
Old 07-14-2008, 04:33 PM
Dave OH32
Dave OH32's Avatar
Nicely done. My SS car regularly gets above 1.4-5 with peaks as high as 1.6x.
Old 07-14-2008, 06:58 PM
TommyBoy72
TommyBoy72's Avatar
The course matters too. I can get 1.6 peak G's if the course is taking advantage of a subtle banking like turning on a hill. For the most part my data is usually around 1.25 sustained by GPS calculation. I can sustain 1.5 on a local track thanks to some minor banking. The hard part is to keep hitting those numbers in a slalom on both sides, my nemesis.
Old 07-14-2008, 11:05 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I looked at some data act. numbers and I pulled 1.50 Left Gs and 1.65 Right Gs at mid ohio, 03 Z06 T1 bars, stock everything else & 275 40 17 Hankooks square, so I'm thinking that's pretty normal.
Old 07-15-2008, 05:52 AM
Jason Staley
Jason Staley's Avatar
Cruise-In III Veteran
Those are some pretty impressive numbers . The best I've managed so far is 1.1 G's. I can't imagine pulling 1.5+, that has to be awesome.
You can post your results by pushing ALT + PRT SCRN and posting a bitmap of the data. That's how I've posted Traqmate data before.
Old 07-15-2008, 09:33 AM
dvandentop
dvandentop's Avatar
or hit print screen past the picture in MSpaint and then save it as a jpg and upload it like a regular pic
Old 07-15-2008, 01:58 PM
97C5inSD
97C5inSD's Avatar
Here we go
Old 07-15-2008, 06:38 PM
LehmanZ06
LehmanZ06's Avatar
1.71 at the Peru National Tour......ASP vette
I gotta think Strelniecks, Mckee in SM2 about 1.8 every now and then.....
PS...it ain't the G's it's what you do with them...good luck
Old 07-15-2008, 07:56 PM
Dave OH32
Dave OH32's Avatar
Concrete doesn't suck, does it David?
To Holy Cow 1.50 and 1.53 Later G's
Old 07-15-2008, 08:11 PM
LehmanZ06
LehmanZ06's Avatar
Concrete rocks !
However, I always see people, not necessarily vette people post, that since nationals is on asphault, that they then won't do concrete. I say fun is fun-----concrete or asphault.
It's kinda funny because some of these other car drivers, don't have a chance in hell of winning, but yet they won't run on concrete.
Old 07-15-2008, 08:13 PM
dvandentop
dvandentop's Avatar
so is it more tricky to run on concrete?
Old 07-15-2008, 08:35 PM
LehmanZ06
LehmanZ06's Avatar
No. Just maybe more fun, as concrete generally has higher grip levels as the tire has more to "grip" on at the macro and micro level.
Quick Reply: Holy Cow 1.50 and 1.53 Later G's
