17" DOT R Not Available/Made???
Old 07-15-2008, 12:57 AM
rikhek
rikhek's Avatar
Default 17" DOT R Not Available/Made???
Thinking of going to 17" wheels to save money on tires. In researching sizes I was surprised to see that neither Toyo or Nitto offer "good" sizes in a 17" DOT R tire.
Nitto has the NT01 in 315/35/17 for the rear but nothing for the front. They have a 275/40/17 and 255/40/17 but these sidewalls and overall OD are too tall.
Toyo doesn't offer a rear or a front in a decent 17" track size.
Am I missing something?
I'm well aware of the Kumho V710 and Hoosier availability & sizing but didn't want to go that route due to cost and longevity.
Your thoughts?
TIA
Rick
Old 07-15-2008, 07:28 AM
AU N EGL
AU N EGL's Avatar
If your going to drive to and from the track on these tires, stick with 18"
or even just extended use.
Old 07-15-2008, 09:04 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,395 Likes on 748 Posts
Kumho V700s can be had in 17" sizes. The V700 Victoracer and V700 ECSTA series are very, *very* similar, and between the two you can get 275s for the front and 315s for the rear.
A bit more grippy than the RA-1/NT-01s, but streetable and much more durable (and slower) than the Hoosier/V710s.
HTH, and have a good one,
Mike
Old 07-15-2008, 09:17 AM
c4cruiser
c4cruiser's Avatar
Just out of curisoty, how much "slower" are either the V700 or Victoracer compared to the V710 on the same car, same course, same driver.
Old 07-15-2008, 09:37 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I run 17 in all around 275 front / 315 rear on CCW classics.
I ran kumho v710s and v700s (rain only)
I now run Hoosier R6 for dry, but still use the v700s for wet.
Old 07-15-2008, 11:03 AM
Diesel68
Diesel68's Avatar
They have plenty for the front in good sizes. The 315 and 275 have the same diameter, and are good as a combo. 315 front is a good combo also. I have used both sizes on track and the street with no problems. 275 can also be plenty fast on a Corvette.
Here are some different size combinations (Front/Rear):
Nitto NT01
275f 275r
275f 315r
315f 315r
Nitto 555RII
275f 275r
Nitto 555RII(F) and 555R drag radial(R)
275f 315r
Toyo RA-1
275f 275r
Old 07-15-2008, 01:17 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
Nothing wrong with the 40 aspect ratio on the 275. I have run Kumho Victor Racer and 710s with 275 front and 315 rear and I have run 315 all around. Biggest problem with 315s in the front is the wheel. An 11 inch wide wheel like a GS wheel will rub against the lower control arm and scrub off your wheel weights.
Bill
Old 07-15-2008, 07:18 PM
VetteDrmr
VetteDrmr's Avatar
Since I autox, where the courses are never the same, it's almost impossible to compare. My gut-feel would be 2-3 seconds on a 100 second course, but it's only a hunch.
The OP was looking for something similar to the RA-1/NT-01, and comparing those to the V700s (I've run both), the Kumhos are better initially, but degrade due to heat-cycles more than the RA-1s/NT-01s. Time difference between the two will be down in the noise for the majority of us.
Have a good one,
Mike
Old 07-15-2008, 10:13 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
The V700 is an oldie but a goodie, but very heavy. V710 and R6 are much lighter in a given size.
Old 07-16-2008, 09:11 AM
PA Z06
PA Z06's Avatar
[QUOTE=Wicked Weasel @ ECS;1566310443]I run 17 in all around 275 front / 315 rear on CCW classics.
Isnt that what the T1 cars run
To 17" DOT R Not Available/Made???
Quick Reply: 17" DOT R Not Available/Made???
