CCW C14 fit on C5 Z06
Old 07-18-2008, 01:09 PM
JSTAN
JSTAN's Avatar
Default CCW C14 fit on C5 Z06
Does anyone know if CCW C14 race wheels with a C6 offsets 18X10 front and 18X11 rear would fit on a C5 Z06?
Old 07-18-2008, 01:22 PM
redtopz
redtopz's Avatar
Not sure what the c6 offsets are, but I'm running ccw c14s as follows:
18x11 front with 8.25 backspace (305/30/18 hoosier)
18x12 rear with 8.75 backspace (335/30/18 hoosier)
No rubbing in front with T1 bar and coilovers. No rubbing in rear with a 5 mm spacer. You should be fine with those wheels.
Quick Reply: CCW C14 fit on C5 Z06
