Help! C6 electrical issues after installing Sparco seats
Installed a Sparco seat on driver's side, complete w/C6 belt buckle. It went in fine, car drove fine, no messages on DIC, except for the airbag light (expected - as the car has side airbags).
The problem is that the interior lights refuse to shut off, even after I shift into reverse (its an 05), turn everything off, exit the car, lock the car etc. Lights just stay on. And they stay on while driving as well. It's as if the car "thinks" I opened the door and am in the car, but haven't started the engine yet.
I have pulled the "Batt 30" fuse to force it off, so the battery does not drain, but this is not a solution. Any ideas / fixes from those who have installed aftermarket seats?
Marc-
Sounds like you bumped the little light switch on the dash to the left of the steering column during your installation. If you push it again, it may shut off the lights.
And, BTW - Aaron Pfadt sells a harness that overrides/fools the computer into thinking the airbag is still connected. If your car has a telescoping wheel, this harness will also re-enable it's adjustment when you have the Sparco's installed. It's about 100 bucks, but I personally MUST be able to adjust the wheel to get comfortable ...
Ahhh, thanks so much guys. That was it!! I'm such a dummy. I was sweatin' bullets there for a bit.
Crystalracer, thanks for the info on Pfadt's relay. I'll look into it. I think I set the telescope to max out right when I bought the car and never moved it. It stayed extended when the seats went in.
I can't say enough about having real shell seats and how much better I stay planted in corners. I was actually driving certain sections noticeably faster than before. Wow.
Glad to help. This is a common 'issue' for Corvette Newbies... RTFM j/k
If your wheel remained extended, then you got lucky. I've heard that certain C6 ECU firmware versions will cause the telescoping wheel to fully retract (in towards the dash) and refuse to move as long as the airbag isn't detected. I haven't installed my Sparco seat yet to see what mine does.
