Race Seats that mount on Vette Manual Seat Track
Received 8,928 Likes
Which seats on the market will bolt to the Manual Seat Track without a bunch of adapter hardware? I have an Ultrashield seat on the driver's side. I want to install a race seat on the passenger side so I can take riders on the track. I want the seat to be moveable and not require a support bar going to the roll bar.
Bill
Bill
oh and...
http://forums.corvetteforum.com/show....php?t=2082658
Take a look at this thread:
http://forums.corvetteforum.com/show...qual+restraint
Apparently if you're running harnesses, you must have a race seat (no OE seats even if you have put some pass-through holes in them).
If you run harnesses for the driver, you must run harnesses for the passenger seat (if you're going to carry an instructor/evaluator or passengers). If you have harnesses, you must have a race seat.
I think the common wisdom is that any race seat will work for either side, so they could be different seats (different models, or even different manufacturers) as long as they are both designed as "race seats".
Bob
Currently I have been able to run with 6 point harnesses on the C5 seat in my Z. It has the Sport Seat Leather on it so there is a pass through in the seat back for the shoulder harnesses but some of the clubs are requiring a race seat Vs a modified stock seat now. The seats do not have to be the same style of seat but do have to be properly installed and it would be better if I had a seat that would move on the passenger side. I am leaning away from an aluminum seat since they require a seat back brace.
I have been looking at a couple different fixed back seats in the $250 range but both seem to require about $200 of custom mounting hardware. I would prefer to just bolt to the stock seat track but it is hard to find any info except from people who have actually installed the seats.
Bill
Bill
I mounted corbeau seats to the passenger rails in my z06. It required using some aluminum strap bars that you can find at home depot or lowes. You just need to drill a couple of holes into them to mount to the rails and the seat.
Bill
Bill
Be careful. The seat and its manufacturer's mount is designed as part of a safety system. So if you do a custom mount make sure it is up to strength needed especially if one uses say a BK belt mount on the race seat hardware.
Agreed, but if you see how these mount you would understand its pretty easy to adapt them. The belts shouldn't really be mounted to the seat.
Here's what I did on the drivers side (using passenger side slider).
http://forums.corvetteforum.com/show....php?t=1931483
