Toe and counting "Flats"
Old 07-21-2008, 09:04 PM
kpctoy
kpctoy's Avatar
Default Toe and counting "Flats"
After spending way more time than I'd like to admit, I took my car to an alignment shop to cross reference what I had done with a Smart Camber gauge and Hardbar's toe plates. Since I had purchased new tires from them last month, I passed on the free alignment at time of installation so I could make my own adjustments and then go back to have them verified.
I have a question on rear toe. After telling the shop I only wanted them to adjust toe front (0 Degrees) and rear (1/16th total) along with thrust angle, the car came back with the following:
Rear Toe
.12L .15R
Now, if I'm not mistaken isn't that just a little over 1/4 total toe? I also understand that 1/16 total toe is recommended for street with 1/4 being towards the extreme for autocross.
So, if everything above is correct, what does each flat equal in regards to toe? I'd like to keep the 1/4 as I do MANY autocross but I also don't want to eat my tires up since I put on 8-10K per season.
My final numbers with me in the car are:
My Settings vs. Alignment Shop Settings
LF Camber -1.9 -2.2
RF Camber -2.0 -2.0
LF Caster 6.4 6.4
RF Caster 6.9 6.9
LF Toe .00 .03
RF Toe .00 .01
Total Toe .00 .04
LR Camber -1.1 -1.3
RR Camber -1.4 -1.2
LR Toe 0.625 .12
RR Tow 0.625 .15
Total Toe .125 .27
So, how may "flats" to take it back to 1/16 total toe or is it suppose to be 1/16 per side for a total of 1/8th for street?
Feedback on the alignment?
Thanks,
Kevin
Old 07-21-2008, 10:01 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
1.5flats is about 1/32", and .1deg is about 1/32". So 1.5 flats on each side is about 1/16". Once I get my thrust angle correct, I do everything symetrically, so I think of 3 flats=1/16" or .2deg.
You should really get a straight edge and tape, and learn to measure toe. That way you always know what you have, and can check the shops' work.
http://www.davidfarmerstuff.com/
Old 07-21-2008, 10:03 PM
davidfarmer
btw, the way I read your numbers, you have about .3deg total toe in the rear, which is just under 1/8" measured at the rim edge.
Old 07-22-2008, 12:22 AM
0RAAMaudio
Former Vendor
RAAMaudio's Avatar
I have had many alignments done and have done many more myself even with very basic tools and I am more accurate than shops are, why?
Because of the mounting method they use to place the "gauges" on the wheels, really not that accurate on any units I have ever seen.
Then again, 99.9% of their work does not have to be all that accurate, just a ball park figure is all most manfs list as in spec anyway.
I verify my work by how the car feels on the track and what the tire temps and wear patterns show and make adjustments accordingly.
To Toe and counting "Flats"
Quick Reply: Toe and counting "Flats"
