What are these tire sizes?
Old 07-24-2008, 05:40 PM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Default What are these tire sizes?
They are Michelin's, what sizes are they in a way I would understand them?
24/64/18
27/68/18
27/65/18
31/71/18
Thanks!
Adam
Old 07-24-2008, 09:30 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think...
24=245mm wide
64=640mmtall
18=18"
24/64/18 = 245/35/18 more or less, the aspect ratio can be a bit tricky to convert.
It's actually easier this way, as you get a direct tire Diameter (64 in this case) instead of a ratio you have to calculate yourself.
Old 07-24-2008, 09:36 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Originally Posted by davidfarmer
I think...
24=245mm wide
64=640mmtall
18=18"
I think you are right!!! Ask you sales guy before you buy to double check.
Randy
PS Look at Tire rack for sizes of your current tire. For a compare or two.
Old 07-24-2008, 10:03 PM
kentz06
kentz06's Avatar
24/64/18
27/68/18
27/65/18
31/71/18
Thanks!
Adam
So Adam, are these new tires for the NCM RA event???
Dean
Old 07-24-2008, 10:25 PM
Adam Boca
Adam Boca's Avatar
thank David and Randy!
So the 27/65/18 may be 275/35/18?
I am getting several tires free, so no dealer to chat with.
Old 07-24-2008, 10:26 PM
Adam Boca
Adam Boca's Avatar
Dean
I wish dean! No RA for me.....
Old 07-24-2008, 10:51 PM
bowmanized
bowmanized's Avatar
Hey Adam,
I represent the Michelin Pilot Racing slicks and I'd be happy to discuss the sizes and recommended wheels for each size. They aren't like regular tires. You need a lot more wheel and there is some mounting info you need too.
Please feel free to give me a call
9162614000
Mike @ Bowmanized
Old 07-24-2008, 11:03 PM
davidfarmer
275/650 would be a 275/35
275/680 would be almost 275/40
I run all kinds of used "scrubs", anything I can get cheap/free. As long as the front tire isn't TALLER than the rear, I'll run it on a C5/C6!
Hey Mike, got any scrubs?????
Old 07-25-2008, 12:11 AM
dvandentop
dvandentop's Avatar
wish they would get scrubs for my 19 rears
Old 07-25-2008, 09:09 AM
davidfarmer
All you have to do is convince all of the Pro racing series' that 19" are better for performance (good luck), and then there will be tons of scrubs. Things moved fast from 15"-16"-17"-18".....then stopped. I think the overall diameter for most race cars has limited the diameter that wheels can go in mass scale.
Of course, there aren't as many large 18" as there used to be, but if you have a Porsche/BMW, there are tons of good used slicks on the market, they just max out around 280-300mm
To What are these tire sizes?
Quick Reply: What are these tire sizes?
