EnglandGreen Insanity Specials !!!!
Supporting Tuner
ENGLANDGREEN INSANITY SPECIALS
The following package specials are for ANY 1997 to 2009 Corvette – Coupe, Z06, Vert, FRC, doesn’t matter. Any late model Corvette is covered.
* Package 1 - $2395 (normally $2895)
• EnglandGreen Custom Cam install with custom street computer tuning for driveability and performance.
* Package 2 - $4290
• EnglandGreen Custom Cam install with custom street computer tuning for driveability and performance- $2395 (normally $2895)
• LG Pro header system, high flow catalytic converters, x-pipe and midpipe -$1895 free installation with cam package (normally $2295)
* Package 3 - $4689
• EnglandGreen Custom Cam install with custom street computer tuning for driveability and performance - $2395 (normally $2895)
• LG Pro header system, high flow catalytic converters, x-pipe and midpipe - $1895 free installation with cam package (normally $2295)
• Vararam - $399 installed (normally $450-$750 installed depending on year and model)
All EnglandGreen custom cam packages include – EnglandGreen custom grind cam, all GM gaskets and seals, LS2 timing chain, High volume, high flow oil pump, 160 degree thermostat, Patriot Extreme dual valve springs with titanium retainers, chromoly hardened pushrods, 25% underdrive crank pulley and new serpentine belt
SEE THIS LINK FOR MORE CAM DETAILS
Stop Press!!!!
For the A4 automatic cars that will require a stall converter with our cam packages, will are offering the RPM Transmission torque converters in any stall speed for $1095 installed. Normal price is $1495. This offer is only valid in conjunction one of the above cam packages.
A La Carte Packages
* Cold Air Intake Packages
Vararam CAI C5 $395 installed
Vararam CAI C6 $495 installed
* Header Package
$1895 with an insane $99 installation
$1995 Installed (normally $2295 to $2495 depending on year and model)
* Gears Packages
RPM Transmissions Differentials
• C5 Micropolished Gears, (any ratio 3.15 to 4.10), HD Clutch packs, C6 Z06 left side shaft, Media blasted case, new seals
$1495 installed (normally $1795)
• C6 Micropolished Gears, (any ratio 3.15 to 4.10), HD Clutch packs, C6 Z06 left side shaft and C6 Z06 two piece right side shaft, Media blasted case, new seals
$1795 installed (normally $2245)
• C6 Z06 Micropolished Gears, (any ratio 3.15 to 4.10), Upgraded carbon Clutch packs, 300M left side shaft, 300M 2 piece right shaft, media blasted case, HD preload springs, new seals
$3095 installed (normally $3545)
For the C6 A6 folks, we are offering RPM Transmissions 3.15 gears, installed with all fluids and includes transmission tuning
$2195
For the A4 2.73 C5 folks, we are offering a brand new GM C5 Z06 differential with 3.42 gears
$1595 installed
* Clutch Package
Textralia OZ 700 Z-Grip clutch and billet flywheel, GM Master cylinder, GM slave cylinder, remote bleeder, pilot bearing, GM flywheel bolts.
$1995 installed (normally $2295)
* Torque Converter Package
RPM Transmission torque converter in any stall speed
$1295 installed. Normal price is $1495.
* Suspension Packages
Pfadt Coilovers $1790 with $199 install
$1989 installed
Pfadt Street Adjustable Swaybars $845 with $99 install
$944 installed
* Street Tune
Full custom street tuning adjusts your spark, air fuel ratio, automatic shift points, etc. for performance, throttle response, gas mileage and driveability. Stock C6/C5, catback, CAI and headers only. No heads/cam/forced induction.
$199 (normally $400)
So what prompted this madness?
Well, EnglandGreen Inc. in Florida and Gulf Coast Performance Inc. in Texas merged forming a new corporation, EnglandGreen Corp. based in Houston, Texas.
Both Jason and Stephen had birthdays recently, then we had the merger – and Stephen recently became a US citizen so we thought we would have a completely insane sale. This sale is crazy and yes, we know that we’ll be taking a bath on some of these specials!!
EnglandGreen relocated to Houston over 30 days ago so it's time for some specials and a grand opening party!!!!!!!!
ALL OF THESE SPECIALS WILL LAST UNTIL MIDNIGHT ON THE DAY OF THE GRAND OPENING PARTY WHICH WILL BE OCTOBER 12th, 2008 (Thanks to Hurricane Ike )
Here at EnglandGreen, we treat all of my customers like our friends and focus on long term repeat business. And we are Corvette owners as well.
Jason's personal 2002 Coupe, Kjun, is heavily modified with a 402ci LS2 twin turbo engine, Whiplash cam, tricked out drivetrain etc. From the latest build with his new massive turbos, he should be somewhere North of 1000 rwhp. Stephen's personal 2001 Coupe, Grond, is running a forged 402ci LS2, Paxton supercharger, Insanity cam, coilovers, hand built tubs, shaved door handles and lots of other custom goodies. All lovingly hand built in-house and our ongoing projects.
We only work on 1997-2009 Corvettes (Generation 5 & 6 Corvettes) and nothing else. And by specializing to such a narrow field, we feel that we can offer what no other Tuners across the entire US can offer - specialized, focused, in-depth expertise.
Please feel free to give us a call to discuss your requirements. You are always welcome to come down to the shop to see what's going on at EnglandGreen. Just call first to make sure we are in. Our hours are Mon-Fri 9am-6pm & by appointment on weekends.
Stephen Rawlins & Jason Theriot
281 464 2800
sales@englandgreen.com
P.S. If you can make it to our Grand Opening Party, please RSVP here: We will have a few giveaways and food for everyone!!!
Attendance List :
Monterrey Bill
Crankshaft
c6user
TXZ0603 - 3
F4 Woozzo
mojo 1 - 2
NTRBL33
DeadFred
admoreno
Tom/99 - 2
falcn1 -2
peter pan
Mike-C5
GO4URS - 2
cgmoose - 2
back 40
Mojo 97 Vett
blazeone
Snowman
Dashbac
Dr. Sumting Wong
oyealiz
VaraRam - 5
Jeff H.
gonbad
DavzC5
LoneStarFRC
gonzo4496 - 2
Black 00 Coup - 6
Aggie John
Lord Vetter - 2
snide
BlueC5Kitten
ProjecT 9
illmac77 - 2
gotjuice?
ZR1BOB
Supporting Tuner
ttt
Supporting Tuner
Supporting Tuner
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Here is a video of one of our most popular cams (Whiplash) that a customer provided to us.
We have over 43,000 posts here between Stephen and I so just do a search for EnglandGreen and you'll have enough info on us to read for a year or two.
Jason
Questions????????
Do you work on C4's?
Do you guys do regular maintenance stuff or only high end tuning?
Do you guys have your own alignment rack?
Nevermind, I see you are exclusively C5 C6.
Supporting Tuner
Another satisfied customer - C5 MN6, headers, intake, stock LS1 heads, Whiplash cam
Stephen,the Whiplash is finally in.I went down to Anthony's house on Sunday to drop off a couple of parts and he turned it over for me and it
sounds wicked
He took it over to Joe Donavan's earlier today for the dyno-tune and what Anthony told me was the RWHP was at 408 with RWTQ at 363 but,I was told his numbers run a little low as well.
I'm picking up the car tomorrow and after hearing it I can't wait to drive it.I'll see if I can get a hold of a video camera to post some
footage.
The Whiplash delivers,big time
Thanks again,my friend
sounds wicked
footage.
Supporting Tuner
Video
Here's a couple of videos Anthony01 was kind enough to take footage of the car on the dyno and at his house.
Max Power = 408.42 Max Torque=363.20
I think Joe was suprised by the numbers being on the low-side considering the mods,I believe he thought it would be in the 430's
for power.Nonetheless the cam sounds incredible and I am pleased with the way it accelerates,that cam revs quick
I kinda felt bad driving through my neighborhood tonight when I got off work tonight,it's like night and day compared with the baby
cam I had previously,that ****** is loud
Stephen,I wanted to thank you again for an awesome product and guidance in getting the right parts for this install.I'm gonna try to give
you a ring on Saturday if your available
Ok,on to the videos,enjoy
Supporting Tuner
Sale now ends October 12th due to Hurricane Ike
Supporting Tuner
ttt
