Managing shoulder cording on older Hoosiers
Now that I've got my first weekend on Hoosiers (S04/5s), I can see that the shoulders are going to cord way before the center of the tread is used.
So, for autocross, is it OK to run the tires until the outer edges just start to cord, then flip them?
TIA, and have a good one,
Mike
Mike
no, they need to be flipped well before cording
even if you flip them at the initial cording point you won't get nearly as long overall effective grip life as doing it earlier
there is a distinct air pressure vs camber relationship; the less camber you have then typically the more pressure your tires need. Most people cord Hoosiers from using too little air pressure, with the front tires being the most critical. Corner edge rollover is the key to determining proper auox pressure for the front, not a tire pyrometer. Overdriving the front tires greatly exacerbates the problem.
Thanks for the replies.
My Vette is the fun car for my wife and I, so I'm only running about -1.0 up front, -0.6 in back for street tires sake.
I'm also running 37 psi front, 33 psi rear. Based on what I'm seeing and hearing, I need to bump that up to 40, 36? These tires are scrubs that were essentially thrown away, so I don't know their history. But that's why I went with throwaways, so I can learn how to care and feed for these tires before getting the good scrubs.
Thanks again, and have a good one,
Mike
Mike
Since I had the slightest cording on the outside edge of a front Hoosier on the 40th run, I thought about flipping all of them on the rims to go another couple of events. I threw out the tire because I don't want to get to an event with a tire that can fail tech inspection.
That's my reason to flip them before you show cord.
-barbara
-barbara
Mike
Mike
