Brake Fluid Shelf Life ???
I thought this would be the best forum to ask this question because we probably buy and use more brake fluid than most.
Does an un-opened container of brake fluid have a shelf life? I know after a container is opened it should be used very soon. My guess is it don't or it would have a date on it, but I don't know for sure. What do you think?
No, it has no specific shelf life. And, an opened container doesn't go bad rapidly, if that was the case you'd have to flush your brake system every month or so. Keep it capped tightly, and it won't absorb much in the way of water vapor (unless you think it's pulling the water vapor through the sides of the bottle).
HTH, and have a good one,
Mike
Mike
Cruise-In VI Veteran
I used to change brake fluid between every event. Now its down to about 3 to 4 events. I bleed the brakes before the event and once during. I figure this case should last at least a couple of years.
Bob
But my case lasts only a year doing 2 cars. If I open a can and don't use it within 3 months then I use the rest for clutch fluid as the clutch fluid stands very little if no chance to boil.
Bob
Bob
I also remember you and Nancy at several events, last was NCM@VIR I think it was. You ran off and left me after you got past the traffic that was holding you up.
Howard
I can see where that would be a good idea. My ATE fluid is in a can instead of a bottle but I can still squeeze out most of the air before I cap it. Good idea, Thanks.
A metal can is the best as its said the plastic does transfer moisture after time. The brands I use are in plastic containers, so I dont buy more than one seasons supply.
So far I havn't bought brake fluid by the case (it would probably be a little cheaper that way), but I do have about 4 Liters on hand and about a 1/2 Liter can open. I better use it as brake fluid very soon it's about 1-1/2 to 2 months old now. Howard
The plastic cans will absorbe moisture but it would take a very loooong time. You'll get more moisture in the fluid by just pouring it into the M/C.
And just FYI, while your m/c's are sealed with the rubber diaphram, I have a race car that has m/c's vented to the air. The calipers get bled before every race but it has nothing to do with moisture.
Received 8,930 Likes
There is no way to know how long the fluid sat on some distributor's shelf before it was shipped to the retailer and then to you so if it had a shelf life it would probably be used up before the fluid got to you.
Bill
Bill
