Sloan Rollback question
Sloan Rollback Trailer Question
I'm driving my Nissan Titan pickup to Dallas next month and plan to buy a new Sloan Rollback trailer to bring back to Washington. I'll be getting one with aluminum decking & fenders and a wind fairing. Dean Sloan recommends I get the 20' version which cost a bit more. The problem is that with a 20' trailer, backing into my driveway which is on a private, tree lined road, will be very difficult if not impossible. I have a pair of wheel caddies which will solve the problem, but I would prefer not to have to resort to that. So my question is, is the 18' version long enough for my '08 ZO6?
Their wind fairing thing is junk! Their trailer is great.
When you get the tire rack on it use a small piece of metal on the bottom for the same purpose. The savings of not buying theirs will pay for the tire rack.
Mine is also 18' If the Nissan is your tow vehicle that will probably be your issue and the AL deck won't solve that problem. Probably only save a couple hundred pounds tops.
I don't understand what you are getting at. Why will my Nissan Titan be the problem? I'll be towing the Corvette on the trailer.
St. Jude Donor '05-'08
I pull my sloan trailer with corvette and tire rack with my Trailblazer SS. With the added weight distribution hitch I have no issues towing my car so I would assume you would have no problems either.
Trailer with Tire Rack
Distribution Hitch
Distribution Hitch
My TBSS with a corvette engine has no issues pulling my trailer at speeds well beyond the speed limit, but after installing the weight distribution hitch I now have more stability at high speeds and on hard braking which means more to me than anything else. Weight is now back on the front tires of the TBSS thus allowing for safer traveling.
If I had a bigger tow vehicle I might think twice about the WDH, but for your average street SUV that you are trying to make into a tow vehicle I would suggest getting one.
Again this is my opinion and I usually error on the side of caution when towing a total of 11K lbs (SUV + Trailer + Car + track supplies + myself)
IMHO the thought of getting a weight distribution hitch should be based on your tow vehicle/trailer weight and stability combination and not just on the trailer.
Received 8,928 Likes
I get along fine with a 16 ft open trailer for my 03Z which I believe is a little longer than a C6Z.
Don't know whether they make front hitch bars for the Nissan but that is one way to get a trailer into a narrow space. Then you can turn around and hitch the trailer at the front of the truck and push the trailer into the driveway. You can be much more precise as you aren't trying to swing a long wheel base back and forth to change the direction of the trailer.
Bill
I have a Dodge Dooley and an Excursion. The Excursion needs the WDH the Dooley does not. Remember once you go over 5000 lb you are not legal without a WDH on either vehicle no matter if you feel you need it or not. You will need it on any lighter vehicle without 4 tires and stiff suspension in the rear. WDH is a big plus especially if you need to do an emergency maneuver. There is towing and getting their and there is driving comfortably, huge difference.
Doubt 2 feet in length will make a difference with practice it will become very easy to get in.
When you don't have a WDH more of the weight of the hitch mounting points is loaded to the rear mounts which may also be why over 5000 it is not legal or not designed for being loaded in that manner.
With the Aluminum deck and fenders, the trailer, I believe, is less than 1400 lbs. So I will be under 5000 lbs. On the WDH, is there hardware that is permanently attached to the truck? Do I need to change out the factory hitch that came with the truck?
If it is a standard 2.25" hitch nothing stays on the truck even if you are under 5,000 a WDH is worth every penny. You can easily throw tools and stuff in the car and be over 5,000 epecially if you take another set of tires.
Do a search online and you can veiw some pricing to compare.
http://www.hitchestogo.com/Weight_Di...%20Systems.htm
Resse and Draw-tite are good brands. Parts availabilty is good for them also. Nothing should break but if you lose something they are common and they will stand behind their products.
below is what I have.
The Trunnion Bar WD System consists of our patented Dual Cam High-Performance Sway Control and our High-Performance Weight-Distributing System in one easy-to-install package. This is the ultimate hitch in detail and by design. No other hitch gives the driver the control this one does at a reasonable price. The Strait-Line Hitch was given this name as its pro-active design literally forces the trailer to stay in a straight line behind the tow vehicle. All parts necessary for towing (except trailer hitch) are supplied.
