How much oil (over) is too much?
I usually run 1/2 to 1 qt. over full for HPDE in the C6. Is 1.5 Qt. over too much and what are the consequences if any? I inadvertently overfilled (with the aid of my helper ...lol) it a little!
Any issues with seals?
CF Senior Member
I'm no expert but I think 1.5 quarts over is too much. When I track my car I put about an extra half quart in. Someone told me even using a full quart over can cause some oil 'ingestion' problems. If it were me, I'd drain some oil out.
1.5 qts over is too much. Not sure if it will cause any harm, but it will blow thru your PCV and you get oil all over your throttle body/intake etc. as wll as out the exhaust and over the back of your car. It is a huge mess.
St. Jude Donor '07
How do you tell exactly? I can only tell by draining for an oil change and then assuming that I got virtually everything out with the change. The C5 is a 6qt capacity so I add 6.5. Above the full line it's really hard to tell what's going on.
C5 XTC
When I have the filter off I also crank the car and run it for ~ 10 seconds. That gets a lot more oil out from the filter area and seems to work. I have a Z51 so there is still some in the cooler.
Headed to VIR now so we wil see if it works I guess ..lol. RAIN .. rats.
That question was asked at the first drivers meeting at Road America and as Tom says, the "man" responsible for all Corvette warranties responded that no extra oil should be added to the C6. Unless someone knows of a better source??????? It IS great to have the GM folks at the NCM events for questions like this one and all the others we ask them.
The LS6, LS2, LS3 are not much different at all in engine design or lubrication. I do not see why for the LS6 it would be required and not for the LS2/3? Doesnt make much sense to me...can someone provide a better reason besides the "man" said so...??
Great info, Tom, I'll forward that on to my C6 buddies!
Have a good one,
Mike
Funny that the "man" would say something contradictory to the Owner's Manual Guess its believe what you hear, not whats typed in your owners manual (of all places).
Fortunately I don't go off of "word of mouth" without associated reason or logic, especially 3rd hand from someone called the "man"
If you, the "man", or anyone else would like to explain what is special/unique about the LS2/LS3 which would require them to NOT use an extra quart while the LS1/LS6 would, then please feel free to to do so...
I dont even own a C6, I am just curious about the justification behind the statement.
Have a good one,
Mike
So what if Lou G said one thing and Roger said another? Who do you believe? Wouldnt it be wise on your behalf to find out the REASONS why they felt the way they did? and make an EDUCATED decision? or maybe you would have Lou and Roger play rock, paper, scissor? LOL...becasue after all reasons dont matter right? just that the "man" said it!! LOL
In general, if/when anything is in question, and an answer is given, wouldn't you want to know why?
Its not as if the answer is consistent, there are conflicting answers for basically the same engines...doesnt that make you a little curious?
To each his own, but NO, I would not take someone's "word", no matter who they were, if they had no reasoning behind their statement, ESPECIALLY if that statement was contradicting another, and furthermore if that statement was heard 3rd hand.
If "cause he said so" is good enough for you, than more power to you ...different strokes for different folks.
throw it
