Fire Extinguisher?
CF Senior Member
Fire Extinguisher?
I'm relocating the location of my fire extinguisher. I'm getting a Brey-Krause mounting bracket for in front of the passenger seat; a Safecraft billet mounting bracket with a pull-pin release; and I'm buying a new fire extinguisher.
My friend mentioned I should get a 5BC rated fire extinguisher. The Safecraft fire extinguisher shown with the billet mounting bracket is a model PB 2.5 lb Halon 1211.
Is the Halon fire extinguisher 'comparable' to a 5BC rating? Will this Halon fire extinguisher comply with NASA requirements or should I find a true 5BC rated fire extinguisher that will fit the billet mounting bracket I want to use?
Thanks for your help.
You might consider one of the new Halotron extinguishers. They're legal, compatible, and they won't destroy any of the computers so liberally sprinkled throughout our cars.
CF Senior Member
Thanks...I'll check into Halotron extinguishers. I hadn't heard of those before. I checked NASA regulations and evidently, the 2.5 lb Halon 1211 is OK. Thanks again for the suggestion.
Dan
www.vetteworksonline.com/videos/Amerex_WS.mov
http://www.vetteworksonline.com/cata...39a381bd46a746
