C4 Wheel Bearings
Old 08-26-2008, 02:41 PM
Kubs
Kubs's Avatar
Received 1,753 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default C4 Wheel Bearings
I have searched the forum and everyone seems to have a different opinion on which wheel bearing are best for track days. I dont have a lot of extra money to spend on the car but can at least a couple people tell me if a Timken bearing from Auto Zone will be ok?
Old 08-26-2008, 04:10 PM
lbs90ZR
lbs90ZR's Avatar
National/ Federal Mogal are the the ones that have held up so har for me. Depending who sells them they are stamped national and very tight to spin when new, another store they looked different and they weren't stamped national and they already felt loose. Have heard about timken's failing. Ac delco's have heard hold up. I think rear taper's are available from somebody on here now.
Old 08-26-2008, 04:13 PM
Kubs
Kubs's Avatar
Thanks. Where did you get yours from and how much were they? I am looking for fronts.
Old 08-26-2008, 04:19 PM
WNDOPDLR
WNDOPDLR's Avatar
Take a look at the new tapered bearings that VanSteel is selling. I am now using them and they seem to be holding up well. I tried the Timkens and was lucky if I could get a weekend out of them. Advance Auto always warranteed them, but they just were not safe. I switched back to GM, then to the VanSteel product. No problems after a season-still going strong.
Old 08-26-2008, 05:50 PM
lbs90ZR
lbs90ZR's Avatar
American driveline and clutch in Dayton ohio, $209. Savage has them for 190 but they were not stamped National and didn't want to try them. Tapers are the way to go though but last I checked they didn't have the fronts for C4 yet.
Old 08-26-2008, 11:45 PM
the blur
the blur's Avatar
stay away from autozone timken, unless you want to change them after 3 laps.
the best I have found is SFK. they take a beating.
the OEM GM also seem to take a beating, but I will say they look identical to timken. So now I only use SFK.
I havn't tried these new tapered, since my SFK are holding up so well.
Old 08-27-2008, 12:49 AM
thehammer69
thehammer69's Avatar
The best i have found is sfk. They take a beating.
The oem gm also seem to take a beating, but i will say they look identical to timken. So now i only use sfk.
I havn't tried these new tapered, since my sfk are holding up so well.
.....skf.....
Old 08-27-2008, 07:08 AM
Kubs
Kubs's Avatar
Where can I find SFK???
Old 08-27-2008, 07:35 AM
the blur
the blur's Avatar
yes, SKF.
that goes to show how long I havn't looked at a bearing box !
But I recommend changing the studs to GM studs before installation.
Old 08-27-2008, 09:20 AM
c4cruiser
c4cruiser's Avatar
I had to replace a front hub on my 87 earlier this year. That hub was a generic white box bearin that I picked up through the shop where I work. I had read about other CF members buying from Rockauto.com. and getting good service and good prices. I checked out their website and found that they have a "generic" bearing, a GM (AC Delco) bearing and a Timken bearing.
From what I had read in other threads, the GM bearing is made by Timken but the Timken bearing sold under its' own brand name is supposed to be better than the GM unit. The GM unit was a higher price on the Rockauto site compared to the brand name Timken.
So I ordered the brand name Timken unit and it came in a box marked "Made in the USA" and the unit was also marked "Made in the USA".
The bearing I received was heavier than the unit that failed and the studs were longer than the one OEM GM hub still on the car and the bearing that failed.
I have only done one track day and 3 autocross events so far with this new hub and it's still tight just like it was when it came out of the box. I would definitely recommend getting the Timken unit from Rockauto.
Just stay away from the stuff at the chain parts stores. These are the white box versions and most likely made in China.
Old 08-27-2008, 11:15 AM
thehammer69
You can find SKF at NAPA. In fact, IIRC, the NAPA branded bearings are SKF.
Old 08-27-2008, 12:16 PM
Kubs
Kubs's Avatar
The only brand I could find online at NAPA was PGB.. or Proformer Bearings. They have the NAPA brand for the rear but I need fronts..
Old 08-27-2008, 12:34 PM
thehammer69
I think you have to go to the store...
Old 08-27-2008, 04:40 PM
ScaryFast
ScaryFast's Avatar
Take a read here.
http://forums.corvetteforum.com/show...post1566870937
Old 08-27-2008, 05:49 PM
thehammer69
Rear: SKF BR930024 for 84-96 C4's
Front: SKF BR930065 for 91-96 C4's
apparently they do not have them for the fronts on pre-91 C4's
http://www.showmetheparts.com/skf/
Old 08-28-2008, 08:28 AM
Kubs
Kubs's Avatar
Thanks. I have a '90. Whats the difference??
Old 08-28-2008, 09:28 AM
ScaryFast
ScaryFast's Avatar
The ABS sensor attachement.
Old 08-29-2008, 03:40 PM
Kubs
Kubs's Avatar
Can It be made to fit? What about Z28 bearings?? Will the ABS work with those?
To C4 Wheel Bearings
Quick Reply: C4 Wheel Bearings
