(FS) Fikse Profile 13 Rims and tons of tires
Old 08-26-2008, 05:31 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default (FS) Fikse Profile 13 Rims and tons of tires
Ok here's the deal I need to sell off some old tires and a set of rims so I can fund Nationals.
1st I have a set of Fikse Profile 13s
These are brand new I put them on my car once because I thought it was going to rain but it never did so they were removed. New never driven on. There is a brand new set of full tread Toyo RA1s mounted. Fronts are 275/35 18 rims are 10" wide, the rears have 335/30 18s and are 12" wide.
http://www.fikse.com/profil.html
Rims only $4k Tires only $800 both rims and tire $4500 this set up was $7k new. If it matters the tires have a world challenge stamp on them. these are available after Sept 15th, tires only wouldn't be shipped until then unless I sell the rims first. I reserve the right to try and sell them as one rather than split them apart.
There is a slight chance they might be driven on once if that happens I will let you know and you could opt out at that point.
As for tires I have
Toyo RA1 Scrubs (2)275/35 18 & (2) 335/30 18s Ran 1:33s at Mid O last month right before dismounting them, lots of life left $200
(4) Hankook C70s 275/40 17 ran a 1:33.8 on these at Mid Ohio in a close to stock C5 Z06 $200
(4) Goodyear GS-CS 315/35 17s lots of life left in them bought from Phoenix and never ran them $200 for the 4
2 Sets of Kuhmo 710s $175 a set
(2) 315 35 18s Rears and (2) 295/40-17s Fronts Some life left great for HPDE
(2) 315 35 18s Kuhmo 710s $90 for the pair
I have one Hoosier A3505 275/40 17 One weekend of use $50
I also have a 18' dove tail trailer, solid box construction this isn't an econo models, tow awesome, electric brakes w 4 new tires and a spare.
I'll post pics when I get a chance. $1750
All prices do not include shipping I will only charge actual shipping charges.
I can take pictures of what ever you like but most are wrapped up in plastic bags so make sure you are serious if you want me to unwrap this stuff.
New Tires, you can still see where the stickers were
RA1 Scrubs
Originally Posted by steponc
What is the ofset or back spacing on the front and rear?
I'm not sure I'll have to check but they do fit my 14" rotors and Alcon Calipers under them.
The fronts fits fine on a C5 the rears would probably stick out a little I run a small spacer to keep the tire from rubbing in the rear. I also have a wide body kit for the rear quarters so they don't stick out on my car.
Old 08-26-2008, 06:00 PM
L98Terror
L98Terror's Avatar
BTW the Fikses and RA1s are available after Sept 15 th
Old 08-26-2008, 08:12 PM
WBHighwind
WBHighwind's Avatar
What compound goodyears?
Old 08-26-2008, 08:27 PM
L98Terror
L98Terror's Avatar
Sorry, GS-CS
To (FS) Fikse Profile 13 Rims and tons of tires
Quick Reply: (FS) Fikse Profile 13 Rims and tons of tires
