Which way does the brake pad taper?
I have a set of race pads that are tapered. I don't remember which orientation the taper originated on the car. Does anyone know if the thinned out end is towards the bottom, or towards the top of the caliper on a stock C6 brake system?
I am asking, because I may need to use these pads again, and I would like to put them in opposite to their original orientation, and "untaper" them.
Received 8,928 Likes
These pads were on the passenger side of a C5 which uses the same brake calipers as your car.
Bill
Bill
Its the "leading edge" of the pad that tapers the most. So look at the way the wheel normally rotates when moving forward and put the thickest end of the pad in the caliper where the rotor is spinning into it. For the front, this would be towards the bottom. On the rear, its towards the top. I swapped my pads like this with my C5 and it did help extend the life of the pads and give better brake feel.
- Mark
- Mark
- Mark
- Mark
Former Vendor
The taper you are seeing is due to caliper flex. You will have a mushier pedal with this tapered set vs the same set that is not tapered.
What we do is flip them. Yes, the taper will be going the wrong way, but it will allow the pad to square back up and then start to re-taper again, but by that time, its time for a new set of pads.
Louis
Louis
- Mark
1 Post
Cruise-In II Veteran
With the total trash that are the PBR manufactured C6ZO6 calipers you get taper in 2 axes! They taper top top to bottom and front to rear. The stock PBR C6ZO6 calipers have the most value as scrap aluminum, recycled into beer cans (if you can get the corroded steel pins out of them). PBR also makes the almost as bad slide rail C5 and C6 calipers. PBR is only good at making tapered pads! Someday, perhaps a Corvette will have decent brakes.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Thanks!
Thanks for all the responses. I have a good idea of what to do now. I'm heading up to WGI for the Sept 1-2 Trackmasters event. Hope to see some fellow Vette owners up there.
