cheap brake rotors
Old 08-29-2008, 03:22 PM
nvygw171
nvygw171's Avatar
Default cheap brake rotors
If not already known.
I've gone 2 days at spring mountain 2x streets of willow 1x willow big track 1x horse theif plus about 20,000 miles of driving on these rotors. They just started to warp after last time at the streets. 20 min run groups at each event. not bad for 120bucks total including shipping.
just odered an new set hopefully they are as good. hopfully this is good for somebody.
http://www.partsgeek.com/catalog/200...ake_rotor.html
Old 08-29-2008, 03:53 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Thanks,
Brembo ... where are they made?
Quite a disparity in rear prices ... are they matched directional?
one says "rear right"
other says "rear" at significantly different price.
Old 08-29-2008, 04:38 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
guess it shows a company like Brembo will drop it's name on anything for a buck.
What is right rear and rear? Might be two rights like a C6Z
Where made for 120 bucks shipped I'll guess China at staggering odds.
guess no worse than NAPA's are now anyway.
Old 08-29-2008, 08:09 PM
nvygw171
nvygw171's Avatar
i used the napa rotors prior, they actually didnt last as long.
it came in a brembo box, i believe these are exactly the same as the drilled rotors... just not drilled.
http://www.partsgeek.com/catalog/200...rotor_set.html
i guess they charge you 400 bucks for that service which is no good for me. The last time i used drilled rotors they started hairlining after one track day and warped it seemed like almost right away. i actually weighed the front brembo and it weighs 16 lbs wich if i remember correctly is about 3 pounds lighter than my last napa's which lead me to beleive they are not the same rotors and i thought they werent going to last as long.
about the directional, heck if i know, which one is which. it doesnt have any marking on the brembo box for me to even know which goes on which. i just made sure the front went on the front, based on part number. and yes they all 4 have diff part numbers. can it make a diff..
i waited to post until i used them, the last thing i want is CF members mad at me because i convinced them to to buy crap.
chinese, maybe but i can def say from own personal they worked for me alot better than the napp's. dont know why, but ther you go.
Old 08-29-2008, 08:42 PM
thehammer69
thehammer69's Avatar
How did you get them for $120...comes up as $141.80 for the set.
Old 08-29-2008, 08:56 PM
John Shiels
iron prices are rising fast and he bought his a while ago I would guess. NAPA's are good for 3 days run hard at best. Are they directionally vained?
Old 08-29-2008, 09:23 PM
nvygw171
nvygw171's Avatar
140 120 whatever, prices could be up or i could have "misremembered". If i remember correctly (which i seem not to be to good at) the cheapest set of nappa rotors i could find a year ago were around twice these prices. yes they are directionally vained, i forgot i crossed that mental milestone last time i put them on
now i feel goofy, thanks. j/k
Old 08-30-2008, 10:08 PM
Z06 Bob
Z06 Bob's Avatar
Default brembo rotors
Ordered two sets of fronts last night. Thanks of the tip.
Old 08-30-2008, 10:26 PM
sperkins
sperkins's Avatar
[right click] - [add to favorites]
To cheap brake rotors
Quick Reply: cheap brake rotors
