Can You Squeeze a Hoosier 305/680R18 on
Old 09-04-2008, 11:27 PM
Sidney004
Sidney004's Avatar
Default Can You Squeeze a Hoosier 305/680R18 on
a 10.5" wheel? Hoosier recommends a rim width of 11.5-12.5 but they also recommend a 11-12 width for their 315/30-18 and everyone runs them on a 10.5 width rim. The tires are GT60's from the Rolex series(has anyone run these?)
Old 09-05-2008, 07:54 AM
PA Z06
PA Z06's Avatar
You should be fine, alot of people run a 315 on a 10.5 wheels, I would assume the ho-hos would be the same
Old 09-05-2008, 08:45 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
make sure it clears your fender on front if it's going there.
Old 09-05-2008, 04:02 PM
Todd Z
Todd Z's Avatar
I have ran the 305 Hoosiers from the Grand Am series on a 10.5" wheel. No problem. Look at Avatar.
Old 09-05-2008, 07:38 PM
Sidney004
Sidney004's Avatar
Todd:
What hot pressures were you running?
To Can You Squeeze a Hoosier 305/680R18 on
Quick Reply: Can You Squeeze a Hoosier 305/680R18 on
