265s on Stock Wheels
Old 09-07-2008, 11:15 PM
avizandum
avizandum's Avatar
Default 265s on Stock Wheels
I'd like to upgrade my setup. I intend to drive to/from events on my tires and have pretty much resigned to R888s.
Will 265 / 305 tires fit and function on stock C6 wheels, and fit the car w/o rubbing? I do mostly AutoX and a few HPDEs.
Old 09-08-2008, 08:19 AM
avizandum
avizandum's Avatar
Hump. (help + bump)
Old 09-08-2008, 11:16 AM
EvilBoffin
EvilBoffin's Avatar
St. Jude Donor '09
I can't answer directly for R888's or those exact sizes, but maybe this will help.
I'm using Hoosier A6's for autocross in 285-30/18 & 315-30/19 sizes on stock wheels on my C6.
They fit fine and do not rub at all. To be honest, they look like a natural fit - line up nicely with the tops of the fender edges and don't stick out. However, keep in mind that I'm currently running -2.0 front / -1.1 rear camber to help the tires work well on-track. That much camber also helps avoid tire contact with the front fender somewhat, if there was any chance of contact otherwise. The car is also lowered slightly, corner-weighted and has a little toe-out in front, toe-in in the rear.
Moral of the story - I think you will be fine, but your actual results can vary based on how aggressive your alignment is, along with the sidewall profile & width of the particular tires you're using.
Old 09-08-2008, 11:38 AM
rbl
rbl's Avatar
Front ... maybe. Back ... no. Look at the overall diameter and required wheel widths.
I think these sizes with the R-888's will work w/stock wheels. Check
Rear ..... 295/30R19Y
Front .... 255/35ZR18Y
Old 09-08-2008, 08:46 PM
carsnguitars
5th Gear
carsnguitars's Avatar
I am using R888's on stock C6 wheels. 275/35 in front and 305/30 in rear with no problems.
Old 09-08-2008, 10:43 PM
Scooter70
Scooter70's Avatar
I've driven on the predecessors to the R888 (Toyo RA1 and Nitto NT01) and they're great tires for dual purpose. Sorry I can't help you with your original question though.
BTW, I also live in Farmington. Hi neighbor.
Old 09-09-2008, 01:37 PM
rbl
rbl's Avatar
That is good to know. The only concern I have is that the stock wheel is 1/2" too narrow for the minimum width for both of those tires. Diameters are fine.
The other sizes seem to meet the minimum wheel width spec. I wonder if that is important?
Old 09-09-2008, 01:52 PM
FredSM
FredSM's Avatar
Same here except I was a little concerned with the 305's in the rear and went 295 . . . sort of dumb because it changed the rake by a good 1/2 inch. Why did I stay so agressive up front and wimp out on the rear? Still, my one and only track day so far on R888s was a huge success coming from OEM rubber, and the tire stayed on the rim. Whole nutha world. Bit more road noise over stock, however.
FM
Old 09-09-2008, 11:58 PM
carsnguitars
5th Gear
It is only out of recommended spec by 1/4" on either side. As you can see from CrystalRacer post, some folks push the envelope even more. At some point, even if the tire fits, you'll get diminishing returns.
I believe that the tire footprint with 275/305 is still better than what you get with the narrower tires and, as you noted, the diameters work well.
To 265s on Stock Wheels
Quick Reply: 265s on Stock Wheels
