Do you rotate pads?
Do you rotate pads?
I have been putting my track pads on the same rotor on the same side for the past 5 track days. Should I be rotating these from like left to right and inside to outside? Apparently I haven't been too hard on them as they have hardly any taper at all. BTW, they are Carbotech xp12s on the front and 10s on the rear. Thanks.
I rotate mine but if there is no taper then it's not such a big deal. Swap inside to outside pad if the thickness is different too.
I see you have a C5Z06, therefore using the same type of pads I do on the C6.
You can't rotate your inboard pads, they have wear indicators and are unique to each side. That means the only rotation you could do would be to swap your outboard pads from one side of the car to the other. Not worth the hassle.
I don't think thats an issue on the track pads as the indicators are not there.
I do notice my outside pad wears a lot faster than inside on the front, it might not be a bad idea to do after 1 or 2 days. I wouldnt do it if the difference is too great.
My car wears the inboard more so I swap that to the outboard and usually side to side depending on taper. If there is one of those metal tangs for wear, I just bend it back out of the way or break it off.
Originally Posted by errance
You guys are not worried about running a pad down towards the end of a track day, and not knowing it because you don't have a wear indicator?
I usually flip pads around after each track day to even out taper wear.
I check everything I can think of after every session. For me I can see the pad but I can also tell how much wear there is by how low my M/C brake fluid gets. As the pad wears the fluid level goes down, remember to check this so as not to get to low! I've seen some near empty M/C's after sessions when people have their hoods up.
Received 8,928 Likes
Bill
