Overriding OEM seat electrinocs???
How do you override (or fool) the seat electronics in a C6 once you remove it in favor of a racing seat?
I don't think it's that easy on a C6 with airbags in the seats (2LT & 3LT). The computer has to sense the airbag receivers, not just that the plugs are reconnected. That's why Pfadt's harness was created, and why it's so expensive.
In any case, I suggest you discuss with Aaron or Jordan at Pfadt Racing before you do anything, as they know the eccentricities of the different model years & option combos that would affect your particular car.
Don't own a C6 but I would bet that is what works too.
Look at this post if you don't believe me. C6 seat electronics & airbags are much more complicated then C5.
http://forums.corvetteforum.com/show...82&postcount=7
Read the rest of the above thread or do a search on "pfadt airbag" in the Autocross&Racing forum for more info. Or just call Aaron.
The same problems happen in some C5's, in fact some C5's won't run without the seat module connected. I know my 2002 Z06 would not run and coded out without the seat module plugged in.
I no longer have that car.
On my 2001 FRC Conversion Vette, I have C6 seats that have heaters and side air bags. Haven't figure out how I will wire them up yet, since the car is still in the body shop getting painted.
I'm sure there is a work around as not all C6's have side air bags in their seats.
The electrical systems of these cars is very complicated and you need a lot of patience working out the issues when you do modifications to it.
I have another set of C6 seats that have no air bags in the sides, so I'm sure if you got a schematic of the system or Pfadt's system you could make it work.
In my case, I NEEDED the telescoping wheel to get into a proper driving position in my C6, so I had to order the big 3LT package that includes side/seat airbags. I bet a lot of tall track rats got stuck with the same issue when they bought their C6's.
Also remember that ALL C6's have ballistic seatbelt pretensioners, which is something I don't want to mess around with down there in the seat harness. I'd personally rather use a pre-made, tested solution like Aaron's and avoid a trip to the dealership to 'reload' my seatbelts!!
I have the 3LT and Z51 packages on an A6, so I am working on using both my feet. But without a good solid seat, reaching with your left foot for the brake takes your body off of the center line making trail braking in a righty challenging
Thanks for the info. I will contact Pfadt.
