Trail braking in a stock C6
Today marked my first day on the Supercar Runflats on the track since last year. Let's just say they were almost scary compare to the R888 (which aren't exactly hot) that I ran on. Other than the lack of grip and response, one of the huge problem I had this past weekend was how nervous the car felt under braking. It seems like under any sort of trail brake, the back-end would step jump out. I am leaning toward a tire problem as the car didn't do that as much on the R888. What do you guys think?
all C6s have Torque Management, that can not be turned off. A good programmer could set the tables so high that it never comes on.
AH & TC are never fully turned OFF even in the OFF position for C6s as well. So any really slip or the rear end would still experience TC.
So throttle steering and trail braking a C6 is not easy to do. a programmer needs to change all the TC, AH, and TQM tables.
Now that said if you get use to having the rear wheels firmly planted with minimal to no slip, the car is still very quick around corner. Just different then the C5s
? I have never felt any traction control or active handling kicking in the corners. And I dont run with the stupid comp mode or any of the BS.
I agree about throttle steer and trail brake, car is more point and shoot.
Having just ridden in the car and seeing this thread I was wondering - was it tuned out of your car? Cause you would have sure triggered it.
Also remember the video from Rd Atl last month from Jarreds car where your rear end was wiggling at T7 I believe - I attributed it to tires....
I am certainly not that good ...
But with an 06 A6 Z51 in Comp mode with R6's, DBA rotors, XP10s and XP8s, I never had any interferance from the AH except for one occasion when I had to seriously brake behind an M5 (applying way too much break) in turn 14 of RA. It let me brake hard and turn at the same time.
For the most part, I was practicing trail braking on the second day without any issues. But I do not believe I was driving any more than 75%.
In May at Brainard (stock brakes, with PS2s), I experimented in turn 3 by taking it in 2nd gear, that was exciting ... Thank God for AH
I just dont see how torque management can kick in when you are trail braking since you are not on the gas. I still believe it is a combination of tires and suspension design that is causing it. I am learning to drive with it, but it seems like the high speed to low speed corners are very tough with the car relatively stock. Someone had mentioned the lack of rear down force is a problem too, but not sure how true that is. Keep in mind this is a bone stock car, so experiences might be different in others.
I don't use traction control or active handling, doesn't want it or care for it. The only drivers aid I like is the ABS, but on the Corvette I am still a little iffy on it as my 350z had a nicer ABS system (not saying it stops better, it just felt better)
I dont think so. We found out why the rear was wiggling. Apparently using the LG coilovers as we found out from the man himself ( brother Tom has a hot line to Lou) we are going to have to lower the car at least 1.5 in. Lou said the car is to high for the rebound. We lowered it at Babers yesterday about .75 in. and it helped dramatically.
I sure did not see any issues with wiggle for you guys at Barbers.
Received 8,928 Likes
It is easy. Throttle steer doesn't mean you are spinning the rear tires. I was throttle steering for the early part of the day today in the rain. I had full TC on due to the constantly changing conditions and the slippery nature of the 6 year old SC tires I am using in place of R tires.
Throttle steering is the judicious use of the throttle pedal to change the yaw of the car. You can do it by leaving off the throttle or adding throttle or a combination of the two.
Bill
Bill
One obvious possibility is that runflats tend to bump steer because of the blocks inside the tire are very stiff. It's symptomatic of the tire. This was discussed here for years on the original Goodyear F1s. Go back to posts from 2003, 2004 and you will see a lot of conversation on the topic.
Maybe you are talking about oversteering where the back end slides out and not "bump steer" where the back end sort of skip shifts over.
If we're talking about oversteer and you don't trail brake as much, does the car understeer? If not, then maybe you are braking too hard into the corner.
Joe
[QUOTE=tmak26b;1567110136
I agree about throttle steer and trail brake, car is more point and shoot.[/QUOTE]
No car is point and shoot, certainly not a C5 or C6. Any car driven with momentum will be faster than if it is driven with a point and shoot style.
Joe
Joe
Joe
Joe
Joe
