Please help with engine rebuild plan!!!
As best as I can tell, I cracked a piston ring in #8 at VIR Thurs. Car was running so awesome. I was hanging with a new Viper ACR for about 5 laps before it went. I am selling the supercharger kit to fund my rebuild. I daily drive my car but I try to track it about once a month or even more if I didn't have to repl clutches, and radiators and brackets and motors. Any thoughts on what a solid bullet proof engine set up would be. TIA!
- hands down
I rebuilt an LS motor - new ARP rod bolts, new caddy lifters, new Comp valvesprings, new ARP head bolts, etc. - spent almost as much as a crate engine with a litte stronger bottom end. Go with a crate...
If you do rebuild - there is nothing wrong with a stock LS6 depending on what you are going to do with it...
A crate LS2.
A crate LS3
Choices of LS2 400HP($5795) LS3 430HP ($6195) or LS3 480 HP($6495)
but
you need to change to 24 reluctor ring
and buy harness adaptors (approx $150)
A crate LS6 405 HP (approx. $6000). Maybe less, you just have to locate one.
no changes necessary.
A forum vendor short block LS6 (approx. $3000)
Unless you are building for a very specific class or need or have to have lots of HP it is difficult to beat the dependability of a crate engine.
A crate LS3
but
mine is a LS6 crate with heads and cam and it has lasted 7-8,000 easy 95% track miles. Still dynos the same as when new.
I saw your car a couple of weeks ago at Williams Performance when I went to get mine. I tried to convince my wife that putting decals on mine would be a cool, but she didn't buy it. She asked it I would get money to put them on, and when I told her no, that was the end of it.
I am hoping to get the head off tomorrow nite and see if it is something simpler like a valve or gasket, but I am not holding my breath. Hopefully the sc kit will sell quickly as there seems to be plenty of interest. That will give me a better idea of my budget. I read about people doing this all the time on the forum, I just can't believe I am now one of them.
It's back at the house now, and ready to rock 'n roll!
While at Road Atlanta in August, unbeknownst to me, my fan wasn't running while I was sitting on grid waiting for practice. The engine got real hot and later that day after qualifying, and before the race, I was checking over everything I noticed a little oil in the water. No water in the oil, but I was concerned even though the car was running fantastic.
Instead of taking a chance and blowing the engine, I put it on the trailer.
I sent an oil sample to Blackstone and they said the oil appeared ok.
Then I took it to Williams and we discussed what the options were. It could be a blown head gasket, or cracked head or a lifted head when it got hot.
So, instead wasting money on tearing it down, I decided to get a new GM long block. They installed it for me, and I'm ready to go back on track.
I have the old motor sitting in the shop at Roar Racing. I talked to a fellow forum member who will buy it after he inspects it for damage.
