What wheels with LG GStop
What wheels other than C5Z and the aftermarket GS fit on a C5 with the LG Gstop brake calipers with no or minimal spacer (< 1/4"). My aftermarket Z06 wheels need almost an 1" and that put the wheels way outside the wheel wells. I looking for a street setup (need a little bling). I use factory C5Z for the track. Oh, I should say that I don't want to dump serious $$$ for wheels either. I'd rather save that for some coil-overs.
Rob
Rob
Received 8,928 Likes
Rob
Rob
For street bling why not get another set of front OEM Z wheels and a set of 17x11 wheels for the rear; or go with 17x11s all the way around. Then you could take the Z wheels you now have and chrome them.
Chromed OEM wheels look much better than most of the aftermarket stuff anyways.
Bill
My AFS (American made at the time) 17x9.5 with GS offset wouldn't fit either. The 17x11 GS offset does fit. Also have another make (China) 17x11 that fits as well. For a while after I went to the G Stop I used a factory Z wheel in front with the AFS 17x11 wheel in the rear.
Bill
Bill
That's actually not a bad idea. I have two sets of factory Z wheels. Any idea how must to chrome?
What is the souce for the GS 17x11s that fit. What size to run a 275 in the front. I assume the 17x11s will work with a 315 for the rear.
Rob
Bill
