What grease for C5 caliper slides?
Old 09-28-2008, 11:38 PM
ZBRA
Support Corvetteforum!
ZBRA's Avatar
Default What grease for C5 caliper slides?
I need to know what grease can hold up to the heat... C5 front calipers... they are brand new, as are the brackets. The slide pins come separate, and do not come greased.
I've got some Mobil 1 wheel bearing grease, but it's only good to 350 degrees. What am I supposed to use on these slide pins?
Just to clarify, these are the pins that bolt to the caliper and slide back and forth in the abutment bracket, allowing the caliper to float back and forth.
Old 09-29-2008, 12:07 AM
Sidney004
Sidney004's Avatar
I use zinc based anti seize similar to:
http://kleen-seize.com/
any product that meets MIL-A-907E will be similar
Old 09-29-2008, 02:01 AM
Last C5
Last C5's Avatar
I use a TS Moly lube that's good to 1200 deg F
http://www.tsmoly.com/catalog/produc...products_id=49
Old 09-29-2008, 10:55 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
I just use the stuff that is on the counter at autozone or advanced auto parts, etc. ... use it on the pins, and on the pad guides top and bottom.
Old 09-29-2008, 04:58 PM
ZBRA
ZBRA's Avatar
That stuff holds up to the heat?
Old 09-29-2008, 05:07 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
I had been using Permatex Anti-Seize. However, for the last couple of years I haven't been using anything and it doesn't seem to matter.
Bill
Old 09-30-2008, 10:50 PM
sperkins
sperkins's Avatar
Old 10-01-2008, 09:21 AM
robvuk
robvuk's Avatar
Bill
Just make sure it's clean and free of dirt/rust.
Old 10-01-2008, 09:51 AM
ZBRA
ZBRA's Avatar
Thanks guys. If anyone else has an option or opinion, please post that as well.
Old 10-01-2008, 10:52 AM
MungoZ06
MungoZ06's Avatar
That's what it's supposed to do ... I find it's fine on the pins; gets baked a bit on the caliper end guide "ears" that slide in the guide slots.
Old 10-01-2008, 09:44 PM
J.Yo
J.Yo's Avatar
I've used the clear green "synthetic" stuff that Permatex makes, and had nothing but problems with it. I take the slide pins out half way through the season, and it looks like caked on mud.
I now use the CRC Synthetic Brake Caliper grease (also sold under the name Sta-lube). It comes in a little plastic tub, or a squeeze tube (very convenient, and I leave it in my toolbox now). I picked it up at NAPA. I've run two seasons now with this stuff, and it holds up very well. I actually started using it on the recommendation of other forum members. Try it...I think you'll like it.
Old 10-04-2008, 01:44 PM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
I use this stuff because I have it lying around:
AMSOIL Series 2000 Synthetic Racing Grease, NLGI #2
I haven't had any problems, but I change my pads pretty often when I'm tracking, so these pins get greased a lot.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 10-04-2008, 05:56 PM
ZBRA
ZBRA's Avatar
I actually have some of that stuff too, and was thinking of using it. Thanks for the warning.
To What grease for C5 caliper slides?
Quick Reply: What grease for C5 caliper slides?
