R888 on Front RA1 on rear
Old 10-02-2008, 05:53 PM
Rob's 73
Rob's 73's Avatar
Default R888 on Front RA1 on rear
I'm having a hard time finding RA1s 275/40/17. I have a brand new set of rears and am looking for the fronts. If I can get an R888 will there be an issue mixing the two types. I should say unshaved as well.
According to this http://www.digitalcorvettes.com/foru...ad.php?t=79145 it looks the tires are very similar except in cornering power and stiffness.
Rob
Old 10-03-2008, 07:53 AM
Rob's 73
Rob's 73's Avatar
Thirty some views and no response. I assume then that I'm not crazy for trying the combo out. I'll see if I can change my order to R888s instead of the toyos. My car understeers a little so I assume it may work to balance or possible induce a little oversteer if they grip more.
Or maybe I didn't get any responses because this site is jacked up.
Old 10-03-2008, 08:37 AM
hemmerman
hemmerman's Avatar
Default Fyi
Rob;
Why don't you try again. Give more information about your car, what kind of racing you're doing? Low speed auto-X or roadracing. Time trails, (single lap times) or mutiple hot laps. What track/tracks you race at. What skill level you race at? and etc.
What did you mean by saying "jacked up"??
Old 10-03-2008, 01:07 PM
Rob's 73
Rob's 73's Avatar
Doing HPDEs in a "slightly" modded 03 Z. T1 sways, LG Gstop, brake cooling, roll bar and H/C. I primarly run Summit Point in advanced/intermediate run groups.
It took me 5 attempts to post a reply is why I said the site is "Jacked up".
Old 10-03-2008, 01:37 PM
cj68
cj68's Avatar
You could probably run the Nitto 555 RIIs (if you can find some), since they are the same tire but different tread. That's what I plan to do with the RA1 rears I just bought, if I can't find matching fronts.
Just a thought.
Chris
Old 10-03-2008, 01:40 PM
wallyman424
wallyman424's Avatar
the r888's are supposed to be very similar in feel/grip as the ra1's. i wouldnt be too concerned about mismatching. just give it a couple laps to feel them out and you'll be fine.
Old 10-03-2008, 02:21 PM
hemmerman
hemmerman's Avatar
There ya go. Sounds like you got some good info. Some times that happens to all of us. Good luck with the tires. I'm a C6ZO6 owner and having trouble getting new rubber. I hope more companies start making matching sets for my car. I drive mine to and from the track. Running on the cords right now.
Old 10-03-2008, 02:31 PM
Rob's 73
Rob's 73's Avatar
Just a thought.
Chris
It looks like Discount Tire has them on special for $179 a piece. I'll mix the Nittos with the RA1s.
To R888 on Front RA1 on rear
Quick Reply: R888 on Front RA1 on rear
