Spherical rod ends, for sway bars. Dimensions for a C4?
St. Jude Donor '03 & '05
I am thinking of having a friend help me fabricate my own for the sway bars. Anyone have any dimensions for a C4, 1993, if it makes any difference.
Rod ends arent expensive, and threaded rods to link the rod ends together isnt hard. So, I am thinking can I make my own?
Kudos for wanting your own parts.
For the dimensions, you're better off getting under the car or pulling the bars off.
That being said, the bars that are on the market have been tested, at the track. That's where the costs add up in building your own. You may or maynot get what you want on the first build especially if you're going to change the bar characteristics.
Before I'd build a working bar from a set of deminsions, I'd build a prototype from thin wall tubing that can be easily cut, tack welded and changed around.
And cheap rod ends are just that - cheap.
just some stuff to think about, Go for it.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've know several people that have tried making them only to have them snap.
That link makes radical angles.
You'll also need to machine some sort of adapter.
Are you looking for the basic dimensions for heim jointed end links used in conjunction with stock bars? If so, I will take a look at my Guildstrand end links and make some notes.
I have been reading many posts of how poly bushings really bind things up, and dont really allow the rear suspension to function properly.
The material of the bars, and quality machine shop with free machining isnt the issue. Knowing I am doing it right is the important part.
The Rod ends can be bought from MSC etc. But material wise, I need to ensure they are correct. Inkenel, Stainless Steel and even titanium are thrown around our shop like nothing, so I know the machinist knows proper machining.
I would like to do the Camber rods, and dog bones. Is there any thing critical to proper assembly, size etc etc?
