Track veteran with a C5. Just bought C6 Z51. Lots of questions...
I've been going to HPDEs since 2000, probably 50+ track days.
My current track car (see sig below, also my daily driver) has DRM brake ducts w/spindle ducts, a Sparco TRS sport seat, a roll bar, a 6-point harness, and an Accusump. I also use R-compound tires (Toyo RA-1s or R888s) that I trailer behind the Vette.
I just bought a 2006 coupe with Z51 and a 6-speed. I'm going to start tracking with this car soon. So I have a dozen questions.
Will my wheels with the r-comp tires fit onto the C6? They are 18 x 9.5 and 18 x 10.5. I would like to keep using these wheels, because they allow me to use scrub tires in sizes that are easy to get. Will they fit over the stock Z51 brakes ok? Are there other issues to consider? Is anyone else using r-comps with a C6 (not Z06), and what wheel & tire sizes do you use?
Will the stock Z51 brakes be ok, or will the drilled rotors tend to crack a lot? Should I get some non-drilled rotors? If so, where can I buy some at a low price?
I'm going to need a 'hardbar' for my 6-point harness. Who makes the best one for a good price?
I've got more questions, but I don't want to put too many questions into one thread...
Bob
Bob
your wheels will fit.
may have TPS issues and put you into reduced power mode. Keep your stock wheels close by
Z51 brakes are just fine. Use them until you have to replace them. brake pads and brake fluid you know about.
Hardbar makes hardbar. if you mean harness bar, well Hardbar of course
Yes, I meant harness bar. I guess Hardbar has become synonymous with harness bar. Like "Kleenex".
The C6 sensors aren't triggered by a magnet like the C5 sensors are.
Bob
Bob
Bob
I don't know all the answers here but I have an 05 Z51. The wheels will fit. I have only run my 05 once so far at Road America. The stock brakes are pretty good though require a bit earlier and steadier pressure. My rotors survived the weekend just fine but I added some Quantum motor sports brake ducts up front and was running on street tires so with R comps you may see a difference. A lot of folks convert the z51 back to the non-z51 setup for the cheaper rotors (I think you swap the caliper bracket and rotor and you have a stock C5/6 setup).
No idea on harness bars. I ran a Brey-Krause bar in my old C5Z06, but If I did something like that again I am not sure how I would go, but new seats would be part of that package for certain.
BR,
Mike
HardbarUSA for the harness bar. I personally went back to the base caliper brackets and the NAPA rotors on my Z51 before going to Wilwoods (where I still run NAPA rotors). Everything you did for your C5 will apply to the C6. C6 wheels are a different offset/backspacing so if you want the perfect fit you'll need new wheels, if not lots of folks are running C5 wheels on C6s. The earlier poster is correct in that you need a tool to program the TPS on the C6 and they use different sensors than the C5.
Is the tool easy to get or do I have to get it from a Chevrolet dealer? (Please tell me I never have to experience another Chevrolet dealer's Parts department.) What does it cost?
Bob
Do a search for "Bartec" both here and in the C6 Tech / Wheels sections. You'll find lots of hits. Prices vary depending on tool. I got mine from http://www.wrighttoolcompany.com/ but I honestly forget the cost.
BTW, to ignore Chevy dealers parts department, go online with Gene Culley @ www.gmpartshouse.com ... (forum sponsor)
Bob
for brake rotors: there are some relatively inexpensive Z51 diameter rotors now avail be. The other option is to go to the stock C5/ C6 rotor, by NAPA / Raybestous and the C6 caliper mounting bracket
and brake ducts are a must, but you know that one
http://forums.corvetteforum.com/show....php?t=2085024
The TPMS computer in the car can only hold 4 sensor ID#'s in its memory, so every time you swap from street to track wheels and back you'll need to do the "relearn" procedure. It only takes about a minute. Below is a video of how to do the procedure (it's using a tool similar to the Trackside, but all the tools would be used in the same manner).
Bob
Congrats Bob on your new ride. Stick with the stock rotors. They are bigger in diameter then the base ones. You can get replacement rotors from ProParts USA 818 888-8904. There made by Centric. They still have drilled holes and only come one sided. Just like stock. I think they sell for around $70 a rotor.
Good luck
Steve
Good luck
Steve
Which ducts are the best for the Z51? Sorry, didn't mean to hijack the thread.
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
I've been racing my '08 Z for a year now with 2 sets of rims/r-comps with no sensors. I have only ONCE had an issue and that was when the street tires came off and one of the tires was truly low in pressure. If the last know pressures to the car at all 4 corners were fine, the sensor-wheels have never caused any issues.
$0.02.
I have an 06 Z-51 and found:
Your wheels will fit.
TPM should not be an issue. I got one warning without them and then no more DIC alerts
Went to C5 brake brackets and NAPA solid rotors. Same stopping for about 13/ the cost.
A Sparco Evo 2 seat will fit just fine. I used the Hardbar mount.
Have fun with it
Have fun with it
