Due to some class rules, Delrin steering rack bushing
Old 10-27-2008, 10:29 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Default Due to some class rules, Delrin steering rack bushing
Well I was informed that some classes in the SCCA require that bushings can't be Metal. So I made up some using the best Delrin I could find. They look the exact same as our Alumium ones, but are a little lighter.
The best part, the price is the same 37.95
Randy
www.dougrippie.com
763-477-9272
Old 10-27-2008, 10:32 AM
95jersey
95jersey's Avatar
Randy
www.dougrippie.com
763-477-9272
How does Delrin compare to Poly? I am thinking about replacing all the bushings in my A-arms and doing some research. I know all about Poly, but are not familiar with Delrin (as a bushing).
Old 10-27-2008, 10:40 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Think of shift *****, delrin is hard plastic.
Old 10-27-2008, 10:47 AM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Old 10-27-2008, 10:52 AM
ZR1 MK
ZR1 MK's Avatar
My A arms bushings are aluminum and delrin. Less deflection and no noise compared to poly. My steering rack is poly, but that was my only choice 10 years ago.
Old 10-27-2008, 10:59 AM
95jersey
95jersey's Avatar
I actually had that shift **** on my C5. How is the durability? I took my shift **** off a couple times while doing work on my C5 and the second time, I just about stripped it putting it back on. It did not seem extremely durable for use as part of something with constant motion. Which of the two will last longer?
I heard also that Delrin does make noise, but is that not necessarily the case? My poly on my C5 made plently of noise.
Old 10-27-2008, 11:14 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Delrin when it comes to moving suspension has the potential of making a ton of noise. Without proper lube they will drive you right out of the car. My old ice racer had two large delrin bushings, that I couldn't keep enough lube in because of the conditions. All I would hear at 8200 rpm, 20 some pounds of boost, anti lag popping, open exhaust and all I could hear was those damn bushings.
But when either properly lubed and/or a bushing that doesn't move around (steering rack), Delrin can be a great option. When it comes to control arms, Mono-ball style suspensions rule.
Randy
Old 10-27-2008, 11:19 AM
ZR1 MK
ZR1 MK's Avatar
Delrin durability as a bushing/bearing is supurb. My A arm bushings are 10 years old and still good as new. They come with grooves and a greae fitting. No noise either. My poly steeer bush doesnt make noise, but there isnt the same motion as A arms.
Old 10-28-2008, 04:22 AM
rustyguns
rustyguns's Avatar
Randy
www.dougrippie.com
763-477-9272
must not be any porsches there, because they run metal a arm bushings stock!
Old 10-28-2008, 07:40 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
may be they can if it is stock
Old 10-28-2008, 09:43 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I think the SCCA factored that in when they classed the car. I heard ASP and maybe SS run these rules.
Randy
Old 10-28-2008, 12:03 PM
Independent1
Independent1's Avatar
St. Jude Donor '08
Choices create dilemmas.
If you had your choice of delrin or aluminum, which would you go with and why?
Old 10-28-2008, 03:52 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I understand that choices create dilemmas. Aluminum if you don't have any rules to live by. If you are in a class where the aluminium is outlawed, then the Delrin becomes a easy choice.
Randy
Old 10-28-2008, 04:11 PM
rustyguns
rustyguns's Avatar
Randy
does Delrin have a website? anyone know the address ?
Old 10-28-2008, 04:17 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
http://en.wikipedia.org/wiki/Acetal_resin
http://www2.dupont.com/Plastics/en_U...in/Delrin.html
Is this what you meant
Randy
Old 10-28-2008, 04:56 PM
rustyguns
rustyguns's Avatar
yes sir! thanks!
To Due to some class rules, Delrin steering rack bushing
Quick Reply: Due to some class rules, Delrin steering rack bushing
