Ride Height for track work - C5 Z06/Stock Suspension
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
I don't know where you heard that, but it is incorrect. Every effort should be made to keep air out of the bottom of the car. Air under the dam is high pressure and tends to lift the car, a very undesirable trait at high speeds.
This is the reason why you see chin spoilers in every modern car, even sedans.
Frank Gonzalez
Frank Gonzalez
in this thread here.
http://forums.corvetteforum.com/auto...-please-4.html
tell me why he is wrong.
Here is the link to the SAE paper on C5 aerodynamics I posted a few times
http://www.sae.org/servlets/productD...D=2002-01-3333
"Abstract:
This paper documents a one shift (10 hour) wind tunnel test program conducted on a Corvette C5 prepared for Sports Car Club of America (S.C.C.A.) World Challenge racing. The testing was conducted at the Canadian National Research Center in Ottawa, Canada. Specific areas of test included front fascia and under tray, rear air discharge, rear wing configuration and angle, B-pillar configuration, and ride height. Standard wind tunnel test procedures were followed. In total twenty-six separate configurations were evaluated. Data for front and rear lift, total drag, and lift/drag (L/D) ratio are provided for each test configuration. The cumulative effects of the aerodynamic changes evaluated in his program, calculated at 192 KPH (120 MPH), increased front down force by 318 N (72 Lb.), and rear down force by 770 N (173 Lb.). Lift/drag ratio was improved from -0.597 to -1.016. These changes increased total drag by 381 N (86 Lb.). Further testing lowering ride height 2.5 cm rear and 5.0 cm front reduced drag by 326 N (73 Lb.) and resulted in a L/D ratio of -1.247. Although data are specific to the Corvette C5, the general principles studied may be applied to any production-based racecar. These modifications should be validated on the racetrack prior to competing to ensure the handling balance can be optimized for the driver and car combination. "
Great $14.00 investment in your car
"Abstract:
Mark Guisti at Phoenix uses a GM part numbered tool to measure the correct suspension angles and subsequent ride heights - both F and R.
IMO-----as long as the lower suspension control arms are not lower than parallel to the ground---THEN you are fine.
If lower than parallel then possible problems.
Note(I also have a slightly stiffer front spring to better control the front)
That's exactly how my car ride height and rake were set up (although Mark didn't do it personally).
Can't beat proper tools and engineering support.
Frank Gonzalez
I believe it was KB aero biscuit that said it.
For maximum downforce and minimum drag, the high pressure air needs to go on top of the car, not below it. High pressure air below the car (applied to the entire area under the car) creates lift, a highly undesirable situation at high speeds.
In addition to creating lift, the high pressure air creates drag because the bottom of the car is anything but smooth, what with all kinds of things protruding into the air path. The top of the car is smooth and shaped in the wind tunnel to minimize drag.
Many race cars use louvered hoods to extract high energy air from the engine compartment. Air comes in through the radiator and below the chin spoiler. If you can make some of it exit through the louvers (rather than run all the way to the rear under the car), you have reduced the amount of lift and drag.
There are also a number of techniques to help extract air and create downforce at the rear. These usually are based on the Bernoulli effect (increasing the air velocity lowers its pressure) and look like extractor (difusers) at the rear of the car. Look at many Ferraris and some MB cars. These are somewhat effective and help decrease lift at the rear of the car.
Hope this helps.
I have to disagree with Chris on this......slamming is bad if you CUT anything, but lowering on stock hardware is fine. I lower cars as far as they will go with not mods (ie, find the adjuster with the LEAST adjustment left, and adjust them all that amount). THEN, I put them on the scales and propperly adjust corner weights.
Is the biggest thing we are after is simply dropping the CG of the car?
Based on my (limited) experience, going way low and with (production car) suspension pieces and you are starting to introduce less than optimal geometry, bump steer, etc.
I'm not attacking either view BTW, I'm genuinely interested in a healthy discussion of such, as I've gotten a variety of viewpoints over the years.
I'm sure this is true but tells us nothing. A ride height is a simple measurement from ground to a known referrence point front and rear. Suspension angles then become automatic within the tolerences of build variances. It is too bad no one can or will tell the numbers. Ride height is a good place to start but there are still a zillion other variables to a good handling car.
Anybody? Anybody? Buhler? Buhler?
#33
Track ride height
I am preparing my 2001 Z06 for track use this spring. This vehicle has been used for track use in the past but the seller partially de-tracked the car prior to sale.
The car has Pfadt Featherlight Coliovers. Street tires are on right now, 305/30/19 rear and 275/35/18 in the front. The current ride height as measured just in front of the front puck lift point is about 4.125, slightly higher on the drivers side. Rear measured just behind the rear puck lift point is 4.25", again just slightly higher on the drivesrs side.
I will be running 315/30/18 square for track set up.
My plan is to install the track tires and adjust ride height (same measuring points) to 5.5' front and 5.75 rear. Then take it to be corner balanced and aligned. The starting point is about .5" lower than stock.
Camber -1.5 to -1.6, toe -.06 front, -1.1 or so camber, +.05 toe rear.
Please weigh in on my plan, sound or flawed? for a car that is primarily track use but driven to the track.
#34
Sure would love to know what the "magic" number for ride height is and at which spot, the jacking points or the centre of the control arm bolts.
I don't know where my car started out (bought it used and have messed with both ends since) so would love to go back to stock and start over.
BTW, I assume the "magic" ride height numbers are based on tires that are staggered like OE and that those of us using square setups either have to lower the front or raise the rear (or both ??). The obvious other issue is that using tires of non stock sizes changes things a lot (Nitto NT01 315s come to mind as they are quite a bit shorter than the stock C5Z rear. Sport cup 2s in 295 sizes are even shorter).
Bossdog, you will want more neg camber front and rear if you can get it, particularly for a 315 square setup. Without it, you will find some pretty uneven tire wear.
#36
Max G’s
