Pics/Instructions to install 5 Point harness in C4?
Old 01-24-2009, 03:19 PM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
Default Pics/Instructions to install 5 Point harness in C4?
I am putting my G-Force 5 point harness back in the Vette, 93. It hasnt been installed ina while, and I dont have the instructions, particulary for the center/crotch strap. R-D sent me instructions, which really dont help much.
So, the R-D racing comes with a plate that goes under the front seat, for the center/crotch stap. But the strap has a triangular attachment with a hole in it for a bolt. Yet the bar doesnt.
If anyone has pics of where this strap attaches to the flat bar they provide, or pics in general, please post them.
Old 01-24-2009, 04:39 PM
RedLS1GTO
RedLS1GTO's Avatar
If the sub belt has a bolt on attachment, you should be able to take it off and put the belt around the bar instead.
Old 01-24-2009, 04:47 PM
steve40th
steve40th's Avatar
Good point. Its a 3 inch wide bar, and the bolt hole apparently goes to the left or right mounting bolt on the seat, so it wouldnt be exactly striaight up to your center, but offset like 6 points where the 2 center straps mount to the seat bolts.
Old 01-24-2009, 06:20 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Whatever you do DON"T put the lower strap over the front.
You can't push a rope, so if you do it won't be doing anything.
I've got my 6pt lower belt going between the seat back and bottom, to the stock seat belt bolts.
If you mount that bar behind the seat, you should be able to do that as well.
Old 01-24-2009, 08:08 PM
steve40th
steve40th's Avatar
Thanks Brian, I was alwasy wondering why it was up front like that. I will see if it will reach to the back mounting bolts, then run it under the seat cushion and to the kahuna area.
Old 01-25-2009, 05:40 PM
2K3Z06
2K3Z06's Avatar
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
http://www.bkauto.com/corvette/r1115.php
this might help
Old 01-25-2009, 08:34 PM
steve40th
steve40th's Avatar
Originally Posted by 2K3Z06
Thanks, it did help
To Pics/Instructions to install 5 Point harness in C4?
Quick Reply: Pics/Instructions to install 5 Point harness in C4?
