Lessons for Newbees
Old 02-08-2009, 09:21 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Default Lessons for Newbees
Lets start a thread of tough lessons that we all have learned the hard way. Feel free to add.
1) Always open the fill plug, before opening the drain plug.
2) Never tighten any fastener until all fasteners are in and snugged up.
3) ...
Old 02-08-2009, 09:34 PM
Z06Fix
Z06Fix's Avatar
3) ...
Could not agree more with the two statments above.
Ohh and from an experience last season with a newbie...... The brake grease goes on the back of the pad, not the friction side
Old 02-08-2009, 09:38 PM
Aardwolf
Aardwolf's Avatar
Really LOOK at how something is assembled BEFORE you take it apart.
Old 02-08-2009, 09:44 PM
TedDBere
TedDBere's Avatar
Be sure to release the parking brake before trying to remove the rear rotors.
Old 02-08-2009, 09:48 PM
froggy47
froggy47's Avatar
Make sure you have enough threads started BEFORE you put an air/elec gun on it.
Old 02-08-2009, 09:51 PM
ErnieN85
ErnieN85's Avatar
never trust some one else to torque your wheels!
Old 02-08-2009, 10:04 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
If the specs say torque something to XX ftlbs, then torque it to that.
The thinking "Tight is good so Tighter must be better" DOES NOT work.
Old 02-08-2009, 10:09 PM
johninar
johninar's Avatar
When you change the oil filter. Check to make sure the old filter ring didn't stick to the engine. The cleanup takes hours depending upon how many seconds the motor runs before you realize what a boneheaded thing you've done.
Old 02-08-2009, 10:13 PM
Kanmer
Kanmer's Avatar
Cruise-In VI Veteran
Check your gas gauge BEFORE heading for grid!!!
Bob
Old 02-08-2009, 10:31 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
can we say digital camera?
Old 02-08-2009, 10:48 PM
mgarfias
mgarfias's Avatar
Purge the accusump BEFORE pulling the oil filter.
Oops.
Old 02-08-2009, 10:59 PM
OCCOMSRAZOR
OCCOMSRAZOR's Avatar
Close the door before tightening the harness.
Old 02-08-2009, 11:17 PM
StealthLT4
StealthLT4's Avatar
Be careful when jacking up your car using the factory jack points. Don't have the jack slip off and do $1,000 of damage to your door...
Old 02-08-2009, 11:29 PM
drivinhard
drivinhard's Avatar
Get jacking pucks that DON'T lock into the frame, at some point you WILL forget them after lowering and deposit them later on your favorite backroad, and/or turn 5 at VIR.
Make sure your hood pins are in before you roll off.
Old 02-08-2009, 11:38 PM
wallyman424
wallyman424's Avatar
1. Make sure you dont leave wooden ramps in your trunk
2. Do not use your only ignition key to try and fix a jammed lock... it WILL bend
3. To prevent 1 and 2, do not bring a hot piece of *** to the track with you.
Old 02-08-2009, 11:51 PM
waddisme
waddisme's Avatar
I am down to 3 pucks now. Also, make sure to remove the extra rotor from trunk well before starting track session. And finally, when people tell you a supercharger does not make a good track car, LISTEN!
Old 02-09-2009, 02:57 AM
flink
flink's Avatar
Surely nobody could be that stupid.
oops.
To Lessons for Newbees
Old 02-09-2009, 06:09 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Work on one side of your car at a time. This way if you forget how something goes back together you can use the other side as a reference.
Old 02-09-2009, 08:47 AM
ghoffman
ghoffman's Avatar
When changing your brake fluid or calipers, etc, never let the brake system go dry. Bleeding the ABS is a royal PINA.
Old 02-09-2009, 08:58 AM
beerkat
beerkat's Avatar
Having a shop manual for your car is a great help.
Quick Reply: Lessons for Newbees
