C5 axle to C4 bearing hub question
Old 02-15-2009, 09:11 PM
Bob Rosencrans
2nd Gear
Bob Rosencrans's Avatar
Default C5 axle to C4 bearing hub question
Hello All.
While helping my brother with his 66 427 restoration he suggested your forum as a favorite for helpful infomation. I'm building a mid-engine
66 corvair with an '04 XLR Northstar, saginaw 4 speed, C5 differential and axles. Its stock rear control arms are similar to a C2 and I would like to modify them for use with C4 or C5 rear brakes.
So here is my question:
Does any one know if a C4 rear bearing /hub will fit onto a C5 axle
and or do C4 C5 hubs share the same 3 bolt pattern? The C4 emergency brake backing plate/caliper mount also looks like a
good part to include. Any ideas to help marry these together would
be greatfully apperciated.
Thanks Bob.
Old 02-16-2009, 09:50 AM
ScaryFast
ScaryFast's Avatar
I can't tell you if the C4 bearings will fit, but if you find that they do, take a look at this link -
http://forums.corvetteforum.com/c4-t...er-prices.html
Everything you wanted to know about C4 wheel bearings.
Old 02-16-2009, 01:04 PM
Bob Rosencrans
2nd Gear
Hi,
Thanks for the great link! It is full of useful information.
Bob
To C5 axle to C4 bearing hub question
Quick Reply: C5 axle to C4 bearing hub question
