C6Z Seat Base for Sparco
I just bought a Sparco seat, I have the sliders and everything else I need....except the base.
I see a lot of guys are fabricating their own seat bases, but I don't think I will have to time to get it done.
Sparco doesn't have a base available yet. I know Pfadt has one but it goes for $300.
Are there any alternatives out there or should I just call Pfadt and place the order?
PS I'm going to VIR for the first time, in 3 weeks. Sweet.
Sparco has a base available. I have it in my car
http://ogracing.com/catalog/2-Car/37...BASE-CHEVROLET
I use the Sparco base and slider. Just keep in mind tall riders beware. With the base, slider, and seat at it lowest setting, with a helmet I have very little clearance. BTW, the slider is not like that in a regular car, it is rock solid once set in place.
I have a hardbar seat mount, not being used right now for my c5, but I think its the same for c5/c6, if you want to test fit your more then welcome to try.
Thanks for the offer, but I need to figure this out pretty quick so I'll do a little more digging. Thanks again for offering, much appreciated.
Jason
If you take the slider out of the equation you may fit, otherwise you will most likely not fit. I am about 5'10.5" and there is less than 1/2" clearence.
I do know from personal experience that the Hardbar rails sit lower than the Sparco, so based on your height, that may be the best route. I am not familar with PDfat
